saph cosworth sideskirts
Old Dec 17, 2003 | 07:59 PM
Default saph cosworth sideskirts
can the plastic blocks that clip onto the sill lip be bought seperate to the sideskirts? if so how much? mine are all broke n i dont wana bodge them unless its necessary
Old Dec 17, 2003 | 08:24 PM
stevedohc16v's Avatar
stevedohc16v
Yes m8 they can be bought from Ford, they are brittle and break easily!
There are 3 different types, each side has 2 front, 3 middle and 2 rear clips,
the finis codes are:
front clips (2 per side) finis code 1659676
Middle clips (3 per side) finis code 1659677
Rear clips (2 per side) finis code 1659678
They are all about £3.20 each.
HTH
Steve
Old Dec 17, 2003 | 08:25 PM
richm's Avatar
richm
yea you can get them individually from Ford, they aren't cheap at £3 each or so..
There are 3 different lengths, short at the front, long at the rear
When u fit them warm them up before you clip them on, otherwise they may well split
Old Dec 17, 2003 | 08:27 PM
richm's Avatar
richm
bollox.. too slow.. LOL
Old Dec 17, 2003 | 10:23 PM
cheeRS will go down the dealers and get some
Old Dec 18, 2003 | 07:34 AM
foreigneRS's Avatar
foreigneRS
Testing the future
yep, definitely do that, particularly in this weather. first rivet them to the side skirt, and then use a hot air gun or hair dryer to warm up the clip bit before clipping them onto the sill seam. otherwise when you go to clip them on, the clip will break in half and you'll say 'bugger, that's 3 quid down the drain'
Old Dec 18, 2003 | 08:53 AM
richm's Avatar
richm
yep, i've done it..
Old Dec 18, 2003 | 11:38 AM
Foreign rs
is that ur car in ur sig ?
Old Dec 19, 2003 | 07:24 AM
foreigneRS's Avatar
foreigneRS
Testing the future
yes, the one on the left is in the paddock area of hockenheim, and the one on the right is in Norfolk
3dr cossie
21
Nov 20, 2015 05:00 PM
jdsjojo
Aug 30, 2015 07:48 PM
lukeeboy149
Aug 22, 2015 04:29 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
