2wd/4x4 question
Old Dec 17, 2003 | 01:28 PM
saphcosgav's Avatar
saphcosgav
Default 2wd/4x4 question
My 2wd saph is missing a bit, I've replaced the phase sensor and dizzy cap and rotar arm, but its still in it, I have a spare set of 4x4 plug leads, should these work alright on my car?
Anything else I should check to try the the miss out, its only a small miss, no backfire or anything....
Thanks lads
Old Dec 17, 2003 | 01:29 PM
Toe Knee's Avatar
Toe Knee
You will need to change the dizzy to a 4x4 one IIRC to run 4x4 leads, u sure the plug gaps are right?! might be 1 slightly out.
Old Dec 17, 2003 | 01:32 PM
saphcosgav's Avatar
saphcosgav
Thanks, i noticed the leads are a little different alright, so just as well I checked..
I gapped the plugs (motocraft) to .8? Its a stage one running 14.5 boost, otherwise standard
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
