Amal Valve
Old Aug 10, 2004 | 08:55 PM
scooby8272's Avatar
scooby8272
Default Amal Valve
Do i need to use an Amal valve on a t3 zetec powered car ?
Old Aug 15, 2004 | 09:25 AM
scooby8272's Avatar
scooby8272
BTT
Old Aug 15, 2004 | 08:35 PM
richm's Avatar
richm
u don't 'need' to, it depends how you want to set and control boost.
At the risk of repeating what you already know, the AMAL valve is essentially an electrically controlled bleed valve, connected between the compressor-to-actuator hose and atmosphere. When normally energised it bleeds of a portion of the actuator control pressure to attain the required boost level. The ECU retains control to switch off the valve (and reduce boost) under unfavourable conditions, eg high inlet air temperatures and/or rpm. as a safety feature.
Alternatively you could set boost directly on the actuator adjustment, or uses a manual bleed valve, but in these cases, the ECU would no longer be able to reduce boost.
Old Aug 15, 2004 | 09:49 PM
scooby8272's Avatar
scooby8272
Thanks for that.
What about using a Electric boost controller.
How do you set the actuator up when using one of these.......
Old Aug 15, 2004 | 09:51 PM
richm's Avatar
richm
yes, that's another alternative, although I Know nothing about setup with these systems..
Old Aug 15, 2004 | 10:06 PM
scooby8272's Avatar
scooby8272
I just cant get my head round how you set the actuator rod ????
Old Aug 16, 2004 | 11:05 PM
Stu @ M Developments's Avatar
PassionFords Creator
Rich M's advice is perfect
As for Controllers, just set the boost at half hole preload and let the controller do the rest
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
