is it the cam? help needed!!!!!
Old Dec 16, 2003 | 07:24 PM
Default is it the cam? help needed!!!!!
my rst is fluffing more than missing! IT DOESNT SEEM TO BE ELECTRICAL OR FUELLING,BUT WITH THE ROCKER COVER REMOVED I HAVE NOTICED THAT NUMBER 3 EXHAUST VALVE IS NOT OPENING AS FAR AS THE OTHER EXH VALVES. WHEN I REMOVED THE THE ROCKER ARM AND TURNED IT OVER BY HAND THE HYDRAULIC TAPPET DOES NOT LIFT OUT OF ITS POT AS MUCH AS THE OTHER TAPPETS. IT DOES NOT RATTLE WHEN RUNNING THOUGH!! COULD THIS BE THE CAMSHAFT AT FAULT??????
Old Dec 17, 2003 | 06:11 PM
ADSRST's Avatar
ADSRST
it is possible it has worn a bit, best thing to do is take it out and check it over.if you need a standard cam thats ok (cheap) pm me i have a couple spare good luck mate
Old Dec 17, 2003 | 06:16 PM
Lee @ Fusion's Avatar
Lee @ Fusion
not come across this one befor , probably cos every rst out there has a new performance cam installed befor it has time to deteriorate as bad as yours .
Will be interesting to see if it is .
If your local to york i and lend u a standard one .
Old Dec 22, 2003 | 08:06 PM
it was the camshaft,number 3 exhaust lobe was nearly round!!!! got a kent cvh35 in her now.thanks for your help guys.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
robnock
Aug 22, 2015 10:51 AM
col93saphcos
Aug 7, 2015 03:21 PM
