3dr rev counter problem
Old Aug 9, 2004 | 07:48 AM
B11GNS's Avatar
B11GNS
Default 3dr rev counter problem
my rev counter is working but it reads a lot less than it should do. It was working fine yesterday but turned it on this morning and it now has the problem. Does anyone know what the problem might be?
Old Aug 9, 2004 | 09:32 AM
rsnissan's Avatar
rsnissan
mine does the same on a 3 dr too. Was speaking to someone about it and they reckoned it might be the connection to the coil.
Would be intrested in some answers to this one as well
Old Aug 9, 2004 | 09:52 AM
B11GNS's Avatar
B11GNS
do you mean the coil on the back of the rev counter itself?
Old Aug 9, 2004 | 10:12 AM
RS500/364's Avatar
RS500/364
right on the 3 door clocks i found loads of dry joints so take the clocks out all aprt get some braid the bit that sokes the solder up and resolder should be better or perfect worked for me
Old Aug 11, 2004 | 04:37 PM
B11GNS's Avatar
B11GNS
Anyone else had this problem?
Old Aug 11, 2004 | 05:16 PM
Mechanic_Wedgie's Avatar
Mechanic_Wedgie
My brothers rev counter was completly dead, we took the blackbox off by the coil and the rev. counter came alive.
Maye this blackbox is also the problem by your car.
Cheers Ruud
Old Aug 19, 2004 | 10:32 AM
B11GNS's Avatar
B11GNS
i have replaced the coil and checked the wire from it to the clocks, all ok. Is there anything else to check before i take the rev counter apart as i dont really want to do that unless i have to?
Old Aug 25, 2004 | 05:24 PM
B11GNS's Avatar
B11GNS
up one last time
Old Aug 26, 2004 | 12:09 PM
uk_christophe's Avatar
uk_christophe
Do you need your book back B11gns?
And no im not going to let Emma drive the car in to work, we have to meet up!
Thanks mate
Chris
http://img7.photobucket.com/albums/v...RS%20Cosworth/
Old Aug 27, 2004 | 06:39 AM
B11GNS's Avatar
B11GNS
No not yet , it sounds like you need it more then me at the mo
BTW the car looks good but i thought she said it was a black one It must have been me not listening properly
Old Aug 27, 2004 | 08:48 AM
uk_christophe
To much for me to handle, i'll book it into the specialist.
Dont worry I never listen to her either
Old Aug 27, 2004 | 09:31 AM
B11GNS's Avatar
B11GNS
it only took me about 2 hours and i hadn't done it before.
Old Aug 27, 2004 | 12:05 PM
uk_christophe
Is that an offer to help?
I'll bring the car to you?
07985105333
Old Aug 27, 2004 | 01:29 PM
B11GNS's Avatar
B11GNS
I could give you a hand but not this weekend as i would need the torque wrenches which i normally borrow from work (i'm off work now until tuesday) but next weekend would be ok just let me know in advance
Old Aug 27, 2004 | 02:51 PM
uk_christophe
Your a true gent!
Old Aug 27, 2004 | 03:55 PM
B11GNS's Avatar
B11GNS
I know! Also was it both camshaft bearings or just one of them?
Old Aug 27, 2004 | 04:02 PM
uk_christophe
Just the one Steve!
Old Sep 1, 2004 | 08:20 AM
uk_christophe
Are you still ok with this weekend steve?
Let me know mate
Old Sep 2, 2004 | 04:37 PM
B11GNS's Avatar
B11GNS
Yep, this weekends fine
Old Sep 3, 2004 | 01:29 PM
uk_christophe
Great I only need your advice and help with this
So I can be round to you whenever your free!
Ring me on 07985105333, and ill come over with me tools.
Text your address and we will come over and chat
Cheers fella!
Old Sep 3, 2004 | 02:00 PM
B11GNS's Avatar
B11GNS
Will do. btw do you have the following parts, a new cam cover gasket, 2 new 1/2 moon seals, a new cam seal (not essential but would be an idea as doing the bearing and obviously i presume you have the bearing itself?
Old Sep 3, 2004 | 02:03 PM
uk_christophe
O YES!
but not the cam seal?
Old Sep 3, 2004 | 02:12 PM
uk_christophe
O YES!
Old Sep 3, 2004 | 02:32 PM
B11GNS's Avatar
B11GNS
i'd personally change it but you can use the old one as long as its ok, also it would have to be saturday as sunday i'm out all day, also dont forget the manual as it has the torque settings
Old Sep 3, 2004 | 02:48 PM
uk_christophe
Saturdays fine earlier the better but i'll leave that upto you as im already pushing my luck.
just let me know when and where?
Thanks again steve
Old Sep 3, 2004 | 02:58 PM
B11GNS's Avatar
B11GNS
yep earlier the better is good for me too let me know the earliest you can be here(as long as its not 5 am ) and i'll PM you my address.
Old Sep 3, 2004 | 03:00 PM
uk_christophe
you name the time and i'll be there!
Old Sep 3, 2004 | 03:15 PM
B11GNS's Avatar
B11GNS
10 am?
Old Sep 3, 2004 | 03:19 PM
uk_christophe
sure no problem!
Old Sep 3, 2004 | 03:23 PM
B11GNS's Avatar
B11GNS
cool, i'll PM you my address
Old Sep 6, 2004 | 08:11 AM
uk_christophe
Just A BIG thanks again steve for all your help on Saturday!!!!
Top fella
Old Sep 6, 2004 | 06:00 PM
B11GNS's Avatar
B11GNS
No problem. All part of the service
TPM961
Jan 15, 2018 10:50 AM
Sierrasideways
Oct 8, 2015 06:37 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
Rammer46
Sep 18, 2015 08:31 AM
Flateric_2002
Sep 15, 2015 08:41 AM
