2wd cos not starting
Old Aug 9, 2004 | 12:32 AM
RScrew69's Avatar
RScrew69
Default 2wd cos not starting
any ideas or common probs as to why my 2wd cos won't start, all its doing is turning over has half a tank of optimax in it.
the other thing that is suspect is when u turn the ignition on the pump isn't buzzing its just goes click like something mechanical turning stopping all of a sudden.
does anyone know where the fuel pump relay is? also what is the correct ampage fuse for the injection fuse in the fuse box holder?
cheers in advance peeps
Old Aug 9, 2004 | 06:27 AM
bob s2zvh's Avatar
bob s2zvh
does the clicking sound like its coming from the clove box?????? this is another problem i've had with mine and eveery time i called the aa it started when they came! turned out to be a wire that push on to the started motor they get loose with age! i just put anew terminal on mine and held it on with 10mm nuts! problem sorted! hope this helps!
Old Aug 12, 2004 | 03:07 PM
RScrew69's Avatar
RScrew69
its not coming from the glovebox, its just as you try turning it over, the pump just goes clink and you don't hear it buzzing and pushing fuel, checked the boot for the fuel cut off switch and thats fine, gonna try changing the pump as i'm pretty sure thats what it is.
cheers
Old Aug 13, 2004 | 07:03 PM
yogi's Avatar
yogi
it maybe that the pressure in the fuel is right so it is clicking. over words the fuel pump relay is switching it off just pull out an injector and put a jug underneath the injector and start her up if it fills you no the pumps fine if it dosent then its a fuel delivery problem
Old Aug 13, 2004 | 07:15 PM
2001ode's Avatar
2001ode
Hi,
Check your security contactor, under the spare wheel.
Regards.
Old Aug 13, 2004 | 07:38 PM
RScrew69's Avatar
RScrew69
i will check that out yogi, have tried the switch and it is fine not popped out.
i might just stick 12v feed direct to pump and see what happens or if it starts up, then i know its the bloody pump, doe sthat sound a good idea?
cheers
Old Aug 14, 2004 | 02:20 PM
yogi's Avatar
yogi
thats fine it willjust keep buzzing just use a spare battery and jump leads eaiest way
FlashRS
13
Aug 31, 2015 06:02 PM
ray barker
Aug 7, 2015 09:00 AM
Tinshaw
Aug 4, 2015 09:16 PM
Old ford
Jul 31, 2015 06:50 AM
