fuel computer thingy
Old Dec 15, 2003 | 10:55 PM
IIvIIitch's Avatar
IIvIIitch
Default fuel computer thingy
any1 know how 2 wire this up in my 3i cab!
wot goes where, wot i need etc...
thanx in advance!
Old Dec 16, 2003 | 11:43 AM
JesseT's Avatar
JesseT
You need the computer, loom, speed sensor and flow sensor and just plug them all in? If there is something specific you want to know, then ask a specific question and I'll try to answer it.
Old Dec 16, 2003 | 01:43 PM
IIvIIitch's Avatar
IIvIIitch
where would i find the sensors?
Old Dec 16, 2003 | 02:21 PM
JesseT's Avatar
JesseT
Usually they are sold with the computer itself. Teh speed sensor is a bit easier to find thanteh fuel flow sensor as it it used in some later Ford models for something not related to the fuel computer.
Old Dec 16, 2003 | 02:53 PM
IIvIIitch's Avatar
IIvIIitch
we;; i picked the computer up from the scrap yard so need 2 know what other bits 2 look for!
cheerz!
Old Dec 16, 2003 | 06:06 PM
Rich's Avatar
Rich
Waste of time IMO,got one in the s2,never shuts up beeping
not reliable either
Rich
Good luck anyway
Old Dec 16, 2003 | 07:57 PM
JesseT's Avatar
JesseT
Mine is dead accurate and has never ever beebed ?!?
Old Dec 16, 2003 | 08:01 PM
stevedohc16v's Avatar
stevedohc16v
Theres a wiring diagram here m8
http://www.xrweb.co.uk/code/fuel.htm
The extra bits you need are the fuel flow sensor and the speed sensor, speed sensors ok as all MFI with the computer and all post 90 EFI cars are fitted with one it goes on the top of your gearbox where the speedo cable goes in between the speedo cable and gearbox, the fuel flow sensor is harder to get hold of as only the MFI cars with the computer fitted as an option have them (the EFI cars use an output from the ECU) the sensor fits on the side of the metering head.
The wiring to the fuel sender is already there under the back seat.
You can fit the fuel computer and wire it up without the speed and fuel flow sensors with just the fuel level sender wired up, this will give you your 'range' function but based on a default of about 25 mpg, it still looks better than the coin tray!
HTH
Steve
Old Dec 16, 2003 | 08:51 PM
jas's Avatar
jas
got one in my s2 and it dont work properly, even brough another complete one and that dont work so to be honest would rely bother, keep meaning to disconnect mine as it to beeps all the time very annoying
Old Dec 16, 2003 | 11:29 PM
IIvIIitch's Avatar
IIvIIitch
i just want it cos it looks better than the coin tray like was said previously!
Old Dec 17, 2003 | 11:44 AM
oriont's Avatar
oriont
if its an efi mate ive got a genuine wiring loom for sale.
thanks
oriont
Old Dec 17, 2003 | 12:26 PM
Any way of wiring on of these into a carb'd setup?
You efi kids seem to get all the best toys.
Old Dec 17, 2003 | 03:12 PM
IIvIIitch's Avatar
IIvIIitch
its an mfi
Old Dec 17, 2003 | 08:21 PM
stevedohc16v
See my reply above m8, thats the link to the wiring diagram and what extras you need, thats how to wire it in to your MFI.
Steve
Old Dec 17, 2003 | 08:48 PM
starturbo's Avatar
starturbo
I got one in my series 2 and I have had it since new.Its ok and It works and always has ,properly.In addition to the sensors that everyone has been talkin about I think there is one in the tank which gives you your range reading.I also have a ford trouble shooting chart for when it goes pearshaped.If you want it let me know.Mine has been more accurate than the gauge.Its the mutts nuts.Dont understand why everyone slags them off?
Old Dec 17, 2003 | 10:44 PM
IIvIIitch's Avatar
IIvIIitch
i'll have a go at the weekend and when i get stuck ask for advice!
Old Dec 17, 2003 | 10:55 PM
the beeping is really annoying
Old Dec 30, 2003 | 05:40 PM
IIvIIitch's Avatar
IIvIIitch
i still have done it, found it sitting in the boot the other day
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
