injectors
Old Dec 15, 2003 | 09:19 PM
ricky's Avatar
ricky
Default injectors
who can solve this problem for me
4x4 saff n0 1 and 2 injector not fireing cange injector ,swap
wire around and still the same problem what could it be and also
no 1 plug getting wet engine loom is in good working order
Old Dec 15, 2003 | 09:48 PM
Doug's Avatar
Doug
Have you actually checked that the injector has a spray ????
also have you checked the feed plug with a noyd or test light to make sure you have a pulse to switch the injector ????
cossie is sequential fires the same as cylinder cycle sounds a bit like head gasket may be blown between 1&2 also carry out a compression check
Doug
Old Dec 16, 2003 | 06:39 AM
ricky's Avatar
ricky
hi m8
have check injector by takeing off the fuelrail with tne injector
still connect to it crank the engine to see them spray and only 1 and2
were spraying swap the wire 2to 3 and tried a cople of other which i now
works and still the same compression ratio has being check it is a bran new
just being built by a good engine builder what else could it possible be
Old Dec 17, 2003 | 09:44 PM
have u tryed swaping the idle conrol valve wire for one of the injector wires i had this problem arfter a head gasket
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
