HELP!!!! Spark/Fuel will not start...Cossie 4X4
Old Aug 7, 2004 | 06:05 AM
svony's Avatar
svony
Default HELP!!!! Spark/Fuel will not start...Cossie 4X4
As the subject says, I have spark at the coil/spark plug, fuel pump primes when the key turns on and fuel at the rail (after a few minutes of cranking the plugs are wet), I also replaced the filter, checked the relays and fuses near the ECU... no luck. Could this be a bad crank sensor?
Before this the car would start but the idle would hunt, this is my first Cossie and I have no idea what else to look for.
Old Aug 24, 2004 | 08:12 AM
ian sibbert's Avatar
ian sibbert
Do a compression check....if thats ok then it's probably the cam timing....cossie's normally start very well...
Old Aug 24, 2004 | 08:24 AM
16vzetec's Avatar
16vzetec
sounds like what happened to me with my rs2000mk5
it was the crank shaft sensor
Old Aug 24, 2004 | 11:47 PM
michael hawkins's Avatar
michael hawkins
Distibutor phase sensor ?
Mine went on my saff and fuel was still coming through to plugs
Old Aug 26, 2004 | 08:51 PM
svony's Avatar
svony
Thanks M8s. I was also looking towards the crank or phase sensor, I orderd up some new sensors so we shall see... Has anyone used the Denso Iridium plugs on their Cossie?
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
