Cossie breathers
Old Dec 15, 2003 | 12:38 AM
RSrussell's Avatar
RSrussell
Default Cossie breathers
If i'm gonna vent both sides of the block, i'm guessing i need a connector tapped in as there isn't one as standard is there?
So its a head removal jobbie yes?
Old Dec 15, 2003 | 12:41 AM
what sort of vent do u mean ? are u talkin about a oil breather system ?
Old Dec 15, 2003 | 12:44 AM
Toe Knee's Avatar
Toe Knee
Nah mate peice of piss, the inlet side just connect it there, the exhaust side theres a nut in the block facing up, unbolt that and go to a hydraulics place and ask for a breather tap the same thread size as the bolt and screw it in You can also get 1 for the cam cover aswell if you wanna, i have with mine but obvously need it off to do it. Can take a few pics tomorrow if you want?! gonna be workin on mine.
Old Dec 15, 2003 | 12:45 AM
RSrussell's Avatar
RSrussell
daddy cool yes mate
nice one tony, don't wanna vent from the cam cover. So whats this nut doing there exactly
Old Dec 15, 2003 | 12:47 AM
Toe Knee's Avatar
Toe Knee
Its a blamking nut, basically a return to sump, was put there for uprating purposes obviously
Old Dec 15, 2003 | 12:53 AM
RSrussell's Avatar
RSrussell
pmsl if it was put there for upgrade purposes, why didn't they fit them with bigger wheels so you can upgrade the brakes easier, and also fit them all as standard with a 200 block
cheers mate
just gotta look into what fittings to have now
Old Dec 15, 2003 | 01:09 AM
Toe Knee's Avatar
Toe Knee
Same reason most cars are like that, cos u gotta pay more to upgrade lol, and the 200block wasnt out when the made the 2wds
Basically u want 1 of thses
But the same thread as the bolt u take out
Old Dec 15, 2003 | 01:12 AM
RSrussell's Avatar
RSrussell
cheers mate
Old Dec 15, 2003 | 01:16 AM
its dead easy to do , although ive fitted a pipe outa the cam cover on mine ,
what make is the one u wanna fit ?
Old Dec 15, 2003 | 01:34 AM
RSrussell's Avatar
RSrussell
philloy mate
Old Dec 15, 2003 | 01:48 AM
not really looked at one of them m8 , i use one of the old baily items , it took me about an hour to fit including drilling and fitting the rocker cover pipe , the only complaint i had was the thickest tube (to atmoshere) was to short and didnt reach anything to clip it to under the car !
Old Dec 15, 2003 | 02:03 AM
RSrussell's Avatar
RSrussell
does anyone know the thread type of the original nut? bsp or metric
Old Dec 15, 2003 | 03:12 AM
RSrussell's Avatar
RSrussell
also roughly whats the temp and pressure of a cossie engine
I've got down 90degs average and 120degs MAX
Pressure 90psi Max to around 30psi when idling warm
Just as a guide, cheers
Rick
Old Dec 15, 2003 | 03:31 AM
Mark_w's Avatar
Mark_w
while you are at hydraulics place get one of these
Old Dec 15, 2003 | 04:29 AM
RSrussell's Avatar
RSrussell
whas that? don't look like a dry sump
Old Dec 15, 2003 | 04:35 AM
Mark_w's Avatar
Mark_w
if you breathe from both sides of block you need to return the oil to the sump plug....buy this from hydraulics place and its job done.....it is actually two parts,the 90 degree fitting and a reducer that screws in the sump(you have to get nut turned down on lathe to fit) easy to drop oil and saves the thread in sump
Old Dec 15, 2003 | 04:41 AM
RSrussell's Avatar
RSrussell
fpmsl ah right i see thats what late nights watchin trisha does to you
good thinking mate gonna get the sump off any way to fit an oil temp gauge (as i don't wanna use the sump nut) i thought there was a standard return though.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
