prob with my 4x4 sapphire cossie
PLEASE PLEASE HELP ME
cossie has developed a problem, when driving on a small amount of throttle its fine,
but, when i give it some boot, it starts to run weird, boost goes all over the place,
and get this....... my rev counter goes mental, i'll be doing 3500-4000rpm
and the rev counter goes of the clock, the actual engine revs stay the same.
thought it might be ignition coil, so i tried a new one, no change.
any ideas guys....... pretty please
i know the actuator is soft, so that might be the boost prob,
but not the rev counter prob
please help me, please please please
you have to check the connectors at the back above the engine. give them a good clean and connect them real tight. i had this to....it turned out that the inside of the connectors are a little wide (because of the age).
good luck
good luck
what do they look like, i have no idea about cossies,
i know my rs turbo like the back of my hand but not the cossie
alright jon its bob that sold you the q plate turbo! hows it going! does your rev counter shoot off the clock then go down to 0????? i had this prob with my car! was told it was the distibutor phase sensor(the wires break down with age) or tdc sensor! so changed both! they cost about Ł20 each! sorted the problem! Also theres a sensor on the inner wing beside the battery remove this and clean the terminals! hope this helps!
do you know anybody that would be interested in s2-89f ,mercury grey,1.8 low comp zvh,piper 285 t2 cam,amber performance hybrid,ahmed bajyoo chip,full samco's,mongoose 4",chromed rocker cover and cross over pipe,smoked lights,recent gearbox from ford ! new clutch only done about 20 miles! 16" mondeo si wheels???????
i thought it was the amal valve to start with, but was told by ford mechanic that it could not be that,
but i still suspect it might be
the distibutor phase sensor is actually in the distributor!!!! the wires on this are very hard to see! your problem sounds like the problem i had which turned to be the this phase sensor!
you'll never guess what the problem was............
a manky rotten air filter, swapped it for a nice new induction kit, what a difference.
thanks anyhoo lads
thanks anyhoo lads
Tony W
09-09-2015 12:08 PM
Adam Graham
06-09-2015 06:04 AM
