Loosing water (FRST)
Old Dec 14, 2003 | 08:23 PM
RS Malik's Avatar
RS Malik
Default Loosing water (FRST)
I seem to be loosing water over a long period of time. I have checked all the pipes/engine for leaks it's not dripping on the road it seems to be evaporating after a few trips
Also on the motorway the faster i go the more the car temp goes up at about 80mph the needle goes just below red, but when i drop to 65/70mph it comes down to half
ps. oil and water are NOT mixing
i would appreciate any help/advice
Thanks
Old Dec 14, 2003 | 10:59 PM
jamie s1's Avatar
jamie s1
its not just a dodgy temperature sender is it ? my s1 used to go haywire on the motorway i used to have to pull over every 2 mile panicking looking for steam lol. i just changed the sensor it was ok after that. is your fan kicking in and have you changed the thermostat. leave it on idle and wait for the fan to start up if it dont you need a new fan switch.
Old Dec 15, 2003 | 01:22 AM
my m8s series 1 used to get hot around 80mph , does your power drop off a little when it shows warm ?
i think he replaced the rad on his cos it was slightly blocked and it sorted it out .
as for loosing the water , does it run ruf when u start it ? or are the carpets damp at all ?
Old Dec 15, 2003 | 04:45 PM
RS Malik's Avatar
RS Malik
fan does kick in ok thermostat is new i'll have to check the temp sensor and yes the passenger footwell is wet could it have something to do with the heater matrix?
Old Dec 15, 2003 | 05:15 PM
jamie s1's Avatar
jamie s1
yeah that happened on my mates suzuki swift check youre core plugs as well
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
