Fuel pump relays...
Old Aug 5, 2004 | 02:23 PM
mk1_orion_boy's Avatar
mk1_orion_boy
Default Fuel pump relays...
Hi,
Are fuel pump relays meant to get hot or warm when they're working?
For some reason my mfi orions has got so hot that part of its started to melt at the connection Sometimes it has a bit of a missfire at about 1.5-2k rpm after a long run. I think they have an economical mode or somthing like that so maybe its not going into uneconomical mode?
Fook knows what im talking about!
Thanks then!
Old Aug 5, 2004 | 08:09 PM
AKRS1's Avatar
AKRS1
Fuel pump relay is known to melt after a while. Better to replace it before it burns your wiring. Cost a bit too
Old Aug 7, 2004 | 07:53 AM
Hatch's Avatar
Hatch
give the connections a clean m8 , its loose connection on the relay pins
Old Aug 7, 2004 | 09:44 PM
mk1_orion_boy
Thanks for the replies.
Still got this problem on a newish one that was in my dads orion and his was running fine so I'm thinking maybe its my fuel pump or fuel filter. It recently had some work done to the pump because one of the brackets holding it on had rusted and they put some sort of bracket thing. Maybe Its shorting somthing out
Do coils do this if they're on their way out?
Sorry too many questions!
Thanks!
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
