over rev please help
Old May 5, 2006 | 02:01 PM
monkeyboyst200's Avatar
monkeyboyst200
Default over rev please help
hi all can anyone help every time the weather gets hot when i change gear or dip the clutch at about 2000rpm tthe engine then races to 3000-4000rpm where it will stay for about 3 secs beforefalling back to normal it never does it in the cold. the car is a 2001 st200.
could it be the bluefin playing up or as i think poss. the mass air flow senser thanks in advance craig
Old May 5, 2006 | 02:04 PM
Dave Henshall's Avatar
Dave Henshall
sticky idle control valve is my guess...
Old May 5, 2006 | 04:42 PM
Dave Henshall
if there is soem oil and muck stuck round it, it my swell up (the metal that is) just enough to make it stick, but im thinking of a cossie one that opens ans closes a small valve, thinking about it , i think the mondeo ones are a servo motor..... but im not sure, if you can get to it, get it off and give it a good clean with some carb cleaner, youll see lots of black gunk come out from it i reckon...
the other option is a ar leak on the inlet manifold, this will make it rev fast at idle aswell...
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
