handling...
Old Aug 4, 2004 | 04:59 PM
jakki's Avatar
jakki
Default handling...
as the days go by my saph seems 2 b getting more n more floaty when it cums 2 taking bends...even powering it in a straight line she twitches all ova...its getting 2 the stage now where i dnt trust the car...wants 2 b sideways all the time?? any idea's why?
bushes mayb?
Old Aug 5, 2004 | 07:08 AM
foreigneRS's Avatar
foreigneRS
Testing the future
maybe bushes, but most likely dampers.
commonly known as shock absorbers, although the springs are actually the shock absorbers.
if you have just a spring, without a damper or with a knackered damper, the car will bounce a lot over a bump or due to weight transfer (like american cars in old movies where you see them stop and the front wobbles up and down for ages).
the damper has a piston that moves through oil, and it's difficult to move through the thick oil with only a small hole in it to allow it to move. that has the effect of letting the spring compress to absorb a bump, but then extend again slowly so that it doesn't keep bouncing.
to check it, you need to bounce each corner hard (maybe get a beefy man to help). as soon as you stop bouncing it, it should settle down and stop. if it does more than 1 bounce (maybe more for a softer family car), then they're knackered. and you should change them in pairs.
new dampers make a hell of a difference to handling, but aren't cheap, particularly front ones if you have to pay to have them fitted.
Escap3
May 8, 2010 10:37 AM
ybturbo
Jun 23, 2009 06:17 PM
