L8 pins
Old May 1, 2006 | 10:38 AM
need4speed00001's Avatar
need4speed00001
Default L8 pins
Does anyone know the pin data for the connector comming out of the l8 ecu?I have fitted it to a2wd saphy and want to fit closed loop llambda,so i need to connect the 3 wire probe.
cheers
Old May 1, 2006 | 04:34 PM
foreigneRS's Avatar
foreigneRS
Testing the future
https://passionford.com/forum/viewtopic.php?t=193872
the output of the lambda sensor needs to go to pin 2 of the ecu. the other 2 wires on the lambda sensor are ground and 12V power supply for the heater.
Chas
Oct 5, 2015 07:13 PM
muz
Sep 30, 2015 08:29 AM
whizzisat114
Sep 1, 2015 02:19 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Roosie
Aug 15, 2015 08:09 PM
