Suddenly running rich
Old Apr 30, 2006 | 11:02 AM
mrjonnie's Avatar
mrjonnie
Default Suddenly running rich
My cossie Westfield was driving fine then suddenly started to splutter. Managed to get home but on inspection the plugs are very black. Have checked all pipes and conections etc. Any ideas? Would a mobile tuner be able to ditect if a sensor is not working?
Thank you
MrJ
Old Apr 30, 2006 | 11:34 AM
BMEP's Avatar
BMEP
Check the hose going to the map sensor. If it comes off the engine will run rich during idle/cruise but will run lean under boost. Could also possibly be a coolant temp sensor problem or the plug has come off.
Good luck.
Old Apr 30, 2006 | 11:47 AM
mrjonnie's Avatar
mrjonnie
Thanks BMEP, will take another look.
MrJ
Old Apr 30, 2006 | 08:13 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
what kind of engine is it mate i can give u values
Old Apr 30, 2006 | 08:46 PM
mrjonnie's Avatar
mrjonnie
The engine is out of a 2wd cossie.
MrJ
Old Apr 30, 2006 | 09:12 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
RIGHT MATE GET A MULTI
best thing to do is to take engine temp sensor out and put in the fridge with a thermometer get as close to 0 deg as pos same with i a t but only to 15-25 deg
readings as follows
coolant temp sensor
c/t/s
0deg= aprox 6000 ohms
40deg=1200 ohms
100deg=180 ohms
i/a/t
intake air temp
between 15+25 deg = aprox3800 ohms
t/p/s
throttle position sensor 2 differ types
type 1
on pins 1+3 with throttle closed =3000 ohms aprox
on pins 1+3 with throttle open fully =1000 ohms aprox
type 2
on pins 1+2 with throttle closed=3000 ohms aprox
on pins 1+2 with throttle open fully 1000 ohms aprox
hope this helps need any more just ask
tommy
Old May 1, 2006 | 04:58 PM
mrjonnie's Avatar
mrjonnie
Off down to Maplins for a meter. Many thanks for all the figures.
dombanks
Sep 21, 2015 08:38 PM
gcfcos
88
Sep 15, 2015 03:48 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
hopper350
Sep 4, 2015 12:53 AM
