can anybody advice me? i got a 1985 rs turbo s2 look a like, cabriolet
i want to install a rs turbo engine etc ,what do need to do? can you help cheers?
Same thing as i did, pretty straight forward really its the same car. One thing i would strongly recommend is NOT putting MFI on it, EFI.........you will be glad you did
You'll want the engine (obviously ), looms you can either go for a MK4 EFI loom (you will lose your auxiliary warning system and have to change plugs for stalks) or use a Fiesta Turbo engine loom and patch into yours, you can choose either between OFAB or OFAC ECU's. You will need an RST exhaust aswell.
If the car is already injection it wont need much else.
