Eibach or Apex?
Old Dec 13, 2003 | 12:11 PM
Jo's Avatar
Jo
Default Eibach or Apex?
I'm upgrading the suspension on my Escos. Dampers will be bilsteins or konis, and springs Apex or Eibach. But can't decide which setup is best.
Any suggestions?
cheers
Jo
Old Dec 13, 2003 | 02:43 PM
cossymad's Avatar
cossymad
Go for H&R thet are the boll*cks.
Do not get Apex as these are not excactly that good.
Old Dec 13, 2003 | 05:47 PM
Jo's Avatar
Jo
Do you mean H&R coilovers?
Old Dec 13, 2003 | 06:03 PM
Eibach's are about as good as it gets. The wire used to wind the spiring is often a smaller diameter than other makes for the same poundage, which reduces the risk of going coilbound. Eibach springs are manufactured to very tight tolerances, and generally speaking, they are usually within a couple of pounds of the rate stated, wheras on other springs you can experience a difference of 3% or more as an avarage. With Eibach's you will find that the first coil is ground flush with the second coil which allows the spring to sit correctly in the spring seat.
Old Dec 13, 2003 | 06:28 PM
Eibach all the way mate
At work we sell many of the eibach springs as they are progressively wound coils giving a much better ride quality
We sell both the above mentioned springs and never get any warranty claims or complaints with the eibach products
Hope this helps
Old Dec 14, 2003 | 03:27 PM
Jo's Avatar
Jo
cheers
Old Dec 15, 2003 | 07:55 AM
cossymad's Avatar
cossymad
As above really then!!! Eibach if your going for springs only on std shocks.
H&R do springs only and coil-overs, and the H&R springs are made to pretty much the same spec as the Eibach ones. I do sell more Eibach ones than H&R's though!!!
Old Dec 23, 2003 | 11:00 AM
Jo's Avatar
Jo
Ordered bilstein shocks and eibach springs this morning from Woodford, hope to have 'm by end of the week
Old Dec 28, 2003 | 10:45 PM
ML's Avatar
ML
Eibach
Matt
Old Dec 29, 2003 | 08:25 PM
SteveB's Avatar
SteveB
Eibach without a doubt
SmudgerByName
52
Jul 28, 2016 06:14 PM
Bailes1992
Sep 3, 2015 02:17 PM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
RsS2daz
Aug 14, 2015 05:26 AM
AKRS1
Jan 20, 2005 07:39 PM
