OVERHEATING SAPH 4X4
Old Apr 23, 2006 | 08:31 PM
TOPPS's Avatar
TOPPS
Default OVERHEATING SAPH 4X4
JUST FITTED A FULL SET OF SAMCO COOLENT HOSES AND EVER SINCE IT OVER HEATS.WHEN I REMOVED THE OLD HOSES THEY WERE FULL OF OILY GUNGE SO I HAVE FLUSHED THE WHOLE SYSTEM RIGHT THROUGH SO THE WATER RUNS CLEAR.I HAVE FITTED A NEW THERMOSTAT,ELECTRIC FAN SWITCH AND HEADER TANK CAP.I FLUSHED THE SYSTEM AGAIN TODAY AND RE-FILLED AND YET IT STILL IS OVERHEATING I HAVE NOTICED THAT IT HAS A LIGHT FILM OF OILY GUNGE IN THE HEADER TANK AGAIN.HAS MY HEAD GASKET GONE OR IS IT SOMERT ELSE.ANY IDEA'S.???????????????
Old Apr 24, 2006 | 07:43 AM
antony215's Avatar
antony215
Escort Rs Turbo
Sounds like the head gasket mate if you've got oil in your water do a compression test on it.
Old Apr 24, 2006 | 07:46 AM
qualittty's Avatar
qualittty
Head gasket problem. I can guarentee that!!!
Old Apr 24, 2006 | 02:25 PM
CosKev3's Avatar
CosKev3
Oil does'nt sound good m8
Take it to a garage and get them to test the gasses in the header tank,they call it 'sniff' test,99% accurate
If it shows up clear,check your rad,feel if its hot all over,could be partially blocked,had this prob on my old saph
Old May 11, 2006 | 09:20 PM
TOPPS's Avatar
TOPPS
JUST TO LET YOU KNOW.I JUST HAD MY RADIATOR RE-CORED,JUST FITTED IT TONIGHT AND RE-FILLED THE SYSTEM AND IT IS AS SWEET AS ANYTHING SUPER COOL.FINGERS CROSSED IT STAYS OK.IT MUST OF BEEN WELL GUNGED UP AND THE PROBLEM CAME TO LIGHT WHEN I FITTED A FULL SET OF HOSES.
Old May 11, 2006 | 09:56 PM
CosKev3's Avatar
CosKev3
Old May 13, 2006 | 08:00 PM
martinmace's Avatar
martinmace
lucky bugger!!
Old May 13, 2006 | 08:16 PM
rapidcossie's Avatar
rapidcossie
good stuff man!
Nov 1, 2015 06:53 PM
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Iain Mac
Sep 30, 2015 09:39 PM
