MOT Failure
Old Apr 19, 2006 | 08:20 AM
Little_Hoss's Avatar
Little_Hoss
Default MOT Failure
the light is permanently on in the dash ov me car (the orange 1) which has resulted init failing its mot as the bloke says theres a problem with the abs
any ideas its an s2(plus theres no sensors in the brake pads-and the brake pads are brand new)
Old Apr 19, 2006 | 08:23 AM
infinityMJD's Avatar
infinityMJD
abs sensors are not in the pads, the ones in the pads are wear sensors, just look for the cabel going to your fronts it will be the only one anywhere near your wheels! the sensors tend to stick in place but remove clean test and see if it worx, if not replace em, that or read my post in your other thread and you will no what to do
Old Apr 19, 2006 | 08:33 AM
Little_Hoss
ok mate!!!
Old Apr 19, 2006 | 06:54 PM
bassy_g's Avatar
bassy_g
wouldnt reccomend it,but last time i had to get my last s2 trhough an mot i had the same problem but was in a hurry so i soldered wire from the batery light bulb to the abs bulb so it went out with the baterry light
Old Apr 20, 2006 | 10:23 PM
K420RS's Avatar
K420RS
s2 abs sensors are not near the wheels they are above the gearbox and are really only belt break sensors.
remember its mechanacial abs not electronic make sure the belts are ok
Old Apr 20, 2006 | 11:27 PM
Drjones's Avatar
Drjones
sorted
Old Apr 21, 2006 | 10:49 PM
cossie604's Avatar
cossie604
lol a scotch lock mends that problem
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
