Breather Oil Return
Old Apr 18, 2006 | 03:13 PM
tosh's Avatar
tosh
Default Breather Oil Return
I've got the sump off to fix an oil leak, so while it's out I want move the oil return to another position because the way it is at the moment is a pain in the arse when it comes to changing the oil.
So if anyone has got any picks of how and where they fitted theres, ie: what position on the sump and what kind of fitting.
This is what it looks like at the moment, (not the best way to do it)
Old Apr 19, 2006 | 05:58 PM
CosKev3's Avatar
CosKev3
Is your breather system breathing from both sides of the block m8???
If its not you can put the oil return into a bung that is underneath the exhaust manifold,you get a fitting with the bailey breather kit to screw into the hole that bung is removed from
Old Apr 19, 2006 | 07:11 PM
tosh's Avatar
tosh
Yes mate it's breathing from both sides
I've now found a place caled EARLS Performance Products on the silverstone complex who can fix me up with some kind of adapter which can be welded on to the side of the sump.
DAZZER
Sep 30, 2015 08:43 PM
