temperature HOT
Old Aug 2, 2004 | 03:35 PM
jakki's Avatar
jakki
Default temperature HOT
having a nightmare with my saph....had it rebuilt had the head ported and polished had a wrc multilayer head gasket put on added a 500 intercooler a breather kit all sorts of goodies n its running hot all the time.....fans kicking in all the time but b4 i got it rebuilt it ran normal....the needle on thew temp is sitting on the O and never moves.
when u go 2 take the cap off the header tank its pressurising up an boiling ova...the water pipes r rock hard but its got a brand new thermostat in n ive bled it all through for any air locks?
im baffled n sik cos dearnt take it anywhere
any ideas?
Old Aug 2, 2004 | 10:08 PM
ML's Avatar
ML
Faulty Rad?
Matt
Old Aug 3, 2004 | 05:01 PM
jakki's Avatar
jakki
only got one fan working on it?
would that make a big differnce?
Old Aug 3, 2004 | 05:09 PM
starturbo's Avatar
starturbo
sounds like theyve screwed up puttin it back together.take it back and tell them what the problem is.good luck
Old Aug 3, 2004 | 05:12 PM
starturbo's Avatar
starturbo
One fan would make a difference.big time.as far as takin the header cap off,dont for gods sake coz you will scald yourself.They all hiss and spit if you loosen the header tank cap.was gonna say that in my earlier reply but i forgot,sorry,good luck
Old Aug 3, 2004 | 05:13 PM
jakki's Avatar
jakki
take it bak?? where 2 me garage??? lol....thats where it was dun at....think the heads gunna ave 2 cum off like...im gunna change the water temp sensor nh bleed it all through...get the timing checked n get a new rad.....then if all else fails its getting stripped bak down
Old Aug 3, 2004 | 11:41 PM
Smit's Avatar
Smit
The 60ft Launch King
Hi Jakki, you still not sorted this?
after our conversation a while ago i would have said the rad....could u borrow some1's??????
got a gut feeling about this...when i had mine rebuilt i had exactly the same problem... (as i said in our conversation) i had a fairly new rad so was quite concerned something serious was wrong when i had the same problem u are decribing... Luckily my friends 4b4 saff was off the road so i borrowed his rad for the afternoon...installed in and bled the system and volia problem sovled.
But as u say u don't wasnt spend some wedge on a rad when it's not the problem..hense me asking if u have a friend who can help you out
good luck
P.s yes that was a tanned me with the glasses on sunday
Old Aug 4, 2004 | 04:16 PM
jakki's Avatar
jakki
lol... forgot all bout our converstaion........is the problem not b4 the rad kicks in though??? it shouldnt run that hot 2 start wth should it??? ill try n sort a radiator out 2 borrow off sumone...
i knew i should ave spoke on sun...was 80% sure it was....u'r not a bad colour r u?? u a sunbed queen???...lol
was looking at ye saf 2....very nice...i might ave 2 ave me name on me window 2......lol
Old Aug 4, 2004 | 04:53 PM
Brigsy's Avatar
Brigsy
do a compression test, or get one of them tests done that tells ya if theres exhaust gasses in the coolant, then ya will kno where ya stand
could possibly be airlock, blocked rad or knackered water pump tho, u tried running it without the thermostat? ive had a brand new thermostat that was knackered
HTH
Old Aug 4, 2004 | 04:55 PM
jakki's Avatar
jakki
yeah ive had the thermostat out n no different...bled it through aswell.... im getting it looked at one sat like at me m8's gargae so will go from there...think it could well b the radiator meself like
Old Aug 4, 2004 | 07:12 PM
DazC's Avatar
DazC
Ford thermostats have been giving problems of recent...
A halfords one (HTK606 is the part number) will fit and is only Ł6ish. Just make sure it's got 82 degrees stamped into it and not 88 as some do....
Old Aug 4, 2004 | 10:10 PM
wimwerf's Avatar
wimwerf
Default Re: temperature HOT
any ideas?
are you sure the engine is not running lean. that could make the temp rise also. i have almost the same spec and the temp is staying no the m all the time.
Old Aug 6, 2004 | 05:42 PM
jakki's Avatar
jakki
dnt knw....hasnt been set up since it was rebuilt......ill keep you's up dated on what happens 2 morra cos im taking it down the garage...... i heard u can get a low temp thermostat last nite or summit like that...is that right?
Old Aug 7, 2004 | 03:23 PM
Guinnless's Avatar
Guinnless
If the head has been ported then your current map is not fuelling correctly. If ya don't sort it it'll possibly blow up when you nail it.
Have the cooling system pressure checked and tested for exhaust gas.
You want a 88 degree stat not an 82 one.
Old Aug 20, 2004 | 04:31 PM
Smit's Avatar
Smit
I had just got back from Ayia Napa 2 days before hand
Any news reguarding the car?
Old Aug 21, 2004 | 07:42 AM
Stu @ M Developments's Avatar
PassionFords Creator
If the pipes are getting hard you have 1 of 4 problems.
1) Air in the water.
2) Headgasket failure or worse.
3) Headertank cap failure.
4) Very excessive temperature. (110+)
4x4s are 82 degree Steve
Old Aug 21, 2004 | 11:47 AM
Guinnless's Avatar
Guinnless
Really?
Old Aug 23, 2004 | 11:14 AM
jakki's Avatar
jakki
well had comperession checked...its fine.......had the head gasket checked its fine.......took me 500 i/c off n the temp dropped a little bit when i put the standard one bak on but its still running on the top of the R...........only other problem is its using oil???? think im gunna ave 2 ave the head off
any idea's why it would use oil i use mobil 1 15/50 n as soon as u put ye foot down the oil disapears
Old Aug 24, 2004 | 06:24 AM
pugo's Avatar
pugo
how many miles has it done ?????
As all engines will use a drop of oil and run a little warm when just built!!!
However i would def get both fans working as that would help
I have a similar spec to you and whenever i pull up anywhere my fans kick in!!!
for the 1st 1000 miles my engine used over 2 litres of oil and ran hot all the time
now it uses minimal oil and temp has settled down( you can still burn your hand on the expansion tank though)
Pugo
" if it ain't broke.....don't fix it"
Old Sep 9, 2004 | 10:04 PM
blaazer2's Avatar
blaazer2
i had the same problem this was due to the car running to lean on boost.......the easiest way to check the rad is,,get the engine up to temp wait for the fans to kick in,wait for them to kick out out then feel up and down the finning on the radiator if there are any cold spots then it is blocked.....never fails!!!
Fiddy
21
Sep 29, 2015 06:10 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
