1.8 2.0 zetec differences
Old Aug 2, 2004 | 01:18 PM
bigmatt-s2rst's Avatar
bigmatt-s2rst
Default 1.8 2.0 zetec differences
ive read on this site thate the 18 and 20 are the same but the block is bored larger on the 20
is this right cos im gunna build a 2.1 zvh and get an 18 at very handy money i also have some 16v vauxhall pistons lined up
thanx in advance
Old Aug 3, 2004 | 02:14 PM
evander's Avatar
evander
Take the 1.8 anyway mate you need bits from it to fit to the 2.0. Of course the 2.0 has a bigger bore.
Old Aug 3, 2004 | 11:35 PM
richm's Avatar
richm
nope, 1.8 and 2.0 blocks are different, you won't get a 1.8 block (81mm bore) bored out to 2.0 (85mm bore) - in fact the GM pistons need more like 86mm.
Curiously if you look at the two blocks, one has "18" cast in the side, the other has "20"
As said though, if the 1.8 is from an escort, then you still need parts - Escort sump and pickup, water pump and pulley, possibly oil pump, alternator bracket..
Old Aug 4, 2004 | 07:49 AM
JesseT's Avatar
JesseT
The 2.0 has siamesed bores as opposed to the 1.8. I think the 2.0 also has oil injection for the pistons.
Old Aug 4, 2004 | 08:32 AM
richm's Avatar
richm
yes, i believe this to be correct. The bore separation on 2.0 is to small to not be siamesed.
Old Aug 4, 2004 | 03:03 PM
bigmatt-s2rst
cheers all, i think ill buy it any way just for the sump pick up and oil pump
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
