S2 wont start
hello i have a S2 that i have just built out of second hand parts ,
i cant get it to run ..
i have got a spark
i have got fuel
all the earths are ok
the car turns over
but the damm thing wont start ..
has anybody got any ideas ???
i have got a spark
i have got fuel
the car turns over
try looking on bottom of engine at front. right underneath the turbo downpipe theres a 2 pin connector block. If the wire has fallen out it wont start. check it connected properly. It called the '......' (cant remember lol) have a look anyway fella. its a sensor!
i think you may have your fireing order wrong, check that when the cam pully is on the marker... the rotor arm is pointing at lead number 1, from there on the order is 1,2,4,3, (clockwise)
No CPS on an MFI, EFI only.
Check the spark order as Biglee said, although he does it in reverse, i prefer to do it the way the engine spins, the plug at :
12 o'clock is cylinder1
9 ................cylinder 3
6.................cylinder 4
3.................cylinder 2
And to look at:
................1
..........3..........2
................4
And to look at:
................1
................4
Have you checked for power to fuelling ECU? It is possible to start and run them without power but its a nightmare. The fuse is in the slot labelled as heated seats IIRC. And check the brown block in the fusebox with KE stamped on it isn't loose (and also that it is there!!)
Fuel will come out of the injectors, like most its a fail safe system, if something fails it will still operate, basically like K Jetronic (XR3i) no enrichment though, and it runs like a bag of poo cold, and wont boost properly. I left the earths off once without noticing and it was a nightmare to start cold, although wasnt as hard as some people find it to be.
I'll double check which fuse it is i always forget, im sure its that one.
The brown thingy can be seen in this picture although i cant remember which slot its in on a S2, as you may notice this is a MK3 fusebox (MK3's dont normally have this
on your pic if you look at the black lucas relay well behind that ive got a small yellow relay ..
when i took this out underneth it there is a burn hole there ..
when the relay gets pluged in it stiil connects ..
do you think this could be the sorce of the problem ???
cheers
I said you fuse box will vary to mine, as mine is a MK3 fusebox. But the burn't hole isn't good, i don't think its got anything to do with your problem but even so.......
Can you take a picture?
had a look with a freind of mine and its ok , the hole is just broke not burnt ..
spoke to the chap i got the car from and he has just told me that the alarm & immobliser might not be bypassed ..
do you think it might be the problem ??
i thought that coz im getting fuel and spark then it was bypassed but i could be wrong ...
If you have fuel and spark its unlikely to have anything to do with the alarm. The alarm usually intervines fuel and spark or ignition.
Have you checked for power to the fuelling ECU etc as i said?
i have checked the power to and from the ecu and the fuel ecu ..
i towed it around the block today and it didnt 1nt to go and every time i pressed the clutch the engine backfired ....
this is starting to piss me off now ....
the firing order is right .
its a new rotor arm and dizzy ..
my dad said that my dizzy might be fcuked ....
what do you reckon ???
ive just tryed another ecu off my mates car and its still the same ...
my head hurts ...
my head hurts ...
yep its all good ..
ive been told that the spark plugs that im using might not be good enuff , there bosh supers ...
will they be ok ???
ive tryed another dizzy , ecu and its still the same ....
will they be ok ???
