1600 CVH Loosing Oil
Old Dec 11, 2003 | 02:59 PM
Default 1600 CVH Loosing Oil
My 1600 CVH is loosing oil.
Fine you think.. there's nothing astounding about that.
But.. Where is it all going?
My stem seals are knackered and it does smoke on startup but surely I wouldn't loose 'that' much oil from this (it drains pretty quick!).
Also, it seems to run down to the 'minimum' mark on the dipstick but never any lower.
Is this purely down to the valve stem oil seals?
If yes, why doesn't it run completely dry?
Damn feck-arse cars.
jon
(btw: I'm a newbie from the XRTwo board so 'Hello Everybody')
Old Dec 11, 2003 | 11:10 PM
you will lose oil,my rst was losing about a litre in a month,and the stem seals were not that bad.If you have no visible oil leak and it only smokes on start up its a good chance that it is just the stem seals. cant answer why it doesnt run completely dry though!!
Old Dec 12, 2003 | 06:20 AM
JesseT's Avatar
JesseT
Most probably it pumps all the oil in to the induction side and burns it. This is because of the dodgy standard breather setup. Undo one of the induction pipes and see if it's all oily. Also undo a spark plug and see if it's all black.
Old Dec 12, 2003 | 12:55 PM
flashpoint's Avatar
flashpoint
If your oil stem seals are worn out/knackered, then oil does seem to diaper at quite an alarming rate, more than you would expect.
Change the stem seals and see if it fixes the oil consumption problem
Steve
Old Dec 13, 2003 | 01:02 AM
Cheers for the replies. .. just wanted to put my mind at rest.
I didn't really want to change the seals as the whole lump may be getting replaced next year (140k can't be good for an engine). I was just curious as to whether something more serious, and pressing, was wrong.
Thanks again
jon
chowfornow
14
Jan 5, 2019 09:01 PM
