P8 L8 ECU on a 4x4 saph
Testing the future
AFAIK, the Escort Cosworth had a 2.5 bar map sensor as standard, so if the chip is written to see the voltage that corresponds to a certain boost on that sensor, you will need to have the same sensor. it could be that the chip is written for a 3 bar map sensor - you should check with GGR
DixieTheKid
11
06-06-2020 11:20 AM
DixieTheKid
14-09-2015 09:04 PM
truffleshuffle
10-09-2015 09:35 PM
