Uprated RST 2 brakes
Old Jul 31, 2004 | 07:00 AM
starturbo's Avatar
starturbo
Default Uprated RST 2 brakes
I want to uprate the brakes on my series 2 but dont know what to get.I notice a lot of people talk on here about using cossie brakes.Is this because they bolt straight on?Any advice about cheapest/easiest would be appreciated.Cheers peeps
Old Jul 31, 2004 | 09:33 AM
rstrob's Avatar
rstrob
First things have u tried uprated discs and pads eg black diamond turbo groove etc?? next is the cossie conversion which are 288mm discs mad 4 it do a conversion using your standard calipers for about £175.. or u could go the whole way and fit cossy calipersm 2 but they are expensive. Next is in my opionion the best conversion using focus st170 discs and calipers they are 300mm discs but u need a minaman of 16inch wheels 4 them 2 fit. this coversion costs about 300-350 depending
hope this helps....
Old Jul 31, 2004 | 12:33 PM
starturbo's Avatar
starturbo
Cheers Rob,thats what I was after m8.Good advice.I will keep my eyes open for st170 bits.I got 17" alloys on it.
Old Jul 31, 2004 | 01:50 PM
swerv's Avatar
swerv
also i might add i have just done all this last week and gone for the cossie set up , but when you do the conversion you have to use a decent fluid as many people over look this and whatever brakes you put on they will be crap.
I have just put in catrol SRF brake fluid and also put braided brake lines in as well , do away with the ABS as well and you should get a good pedal feel as well!!
Old Jul 31, 2004 | 03:52 PM
starturbo's Avatar
starturbo
Noted everything you said.Only thing is the abs.I actually rate it coz twice now its saved me from hitting someone.Mine really does work.Like to keep it on the car m8.
Old Jul 31, 2004 | 08:45 PM
swerv's Avatar
swerv
thats fine if you want to keep it just make sure you beeld the system properly , you will see the 2 pots at the back of the engine with brake lines going through them from the master cylinder these are to do with the ABS , im not 100% if you have to empty these out manually or they just bleed with the system
Old Aug 3, 2004 | 04:27 PM
rstrob's Avatar
rstrob
Stu there is a company that does the st170 coversion all in with uprated discs I will dig the no out.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
gcfcos
59
Oct 6, 2015 05:04 PM
A.t.p
Sep 29, 2015 05:04 PM
