***urgent help again*** key and ignition problem
Old Mar 21, 2006 | 08:27 AM
statto's Avatar
statto
Default ***urgent help again*** key and ignition problem
went to start the escort lastnite and the key won't turn past the on position.
the crack is, turn off the imobilisers and then turn the key and all the ignition lights come on on the dash board, but thats as far as the key will turn, therefore i can't get the car to start tried everything but key just won't turn any farther
any idea's would be great
Old Mar 21, 2006 | 08:56 AM
se mk3 cabbie's Avatar
se mk3 cabbie
if the key itself turns further but nothing happens it can be the box behind ignition barrel, happened to me before, the plastic slot wears away, take off plastic steering column surround, undo the two tiny screws under the left hand side of barrel, pull apart and check the slot on middle, hope this helps
Old Mar 21, 2006 | 09:13 AM
statto's Avatar
statto
nah thats the problem, key won't physical turn past the on postion on the ignition, once the dash board lights come on, the key just won't turn any farthur
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flatlinedan
Sep 18, 2015 12:41 PM
NC53
Sep 13, 2015 03:05 PM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
