escort mk6 2.o zetec conversion
Old Mar 15, 2006 | 08:05 PM
richiepearce1966's Avatar
richiepearce1966
Default escort mk6 2.o zetec conversion
hi not sure if any one can help...bought a mk6 which the owner said had 2.0 zetec conversion, it still had 1.6 tb so changed this for a 2.0 tb all ok...then managed to get 2.0 maf car did not like that one bit...checked ecu and still fitted with 1.6 ecu...got hold of non pats 2.0 mondeo ecu and wired it in fitted 2.0 maf started first time a bit lumpy but i thought it needs to reset it self...once it had found its base idle i drove it would not rev past 4000 in any gear unless it was on 1/2 throttle any more than that forget it...low rev range almost to lumpy to drive...engine no are not on crank case so any othe way to find out if it is a 2.0 without removing head or maybe some other fault thanks
Old Mar 15, 2006 | 09:09 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
take of the manifold and above the crankcase braether it will say 1.6 1.8 2.0 this is the block size
as for the dodgy idle etc
1 did the car idle funny when u changed the throttle body or when u added the maf
both send out a 0-5v signal sounds like 1 of them is hitting 5 v before its ment to
but need bit more info on this 1 mate
Old Mar 15, 2006 | 09:23 PM
richiepearce1966
had the 2.0 tb all ok...put on 2.0 maf would not idle as it still had the 1.6 ecu...
replaced ecu and maf for 2.0 spec
then probs...
tried with 1.6 maf still probs
now reversed wiring and put 1.6 ecu and maf until i can sort out cause
cheers for info on block
Old Mar 16, 2006 | 06:06 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
iratic idle sounds like an air leak in inlet manifols check for leaks
did u replace t/b with new gaskets chek stubs at rrar of maniold
can u here hissing noise in the bay??
Old Mar 16, 2006 | 07:51 AM
richiepearce1966
i think the prob is with the 2.0 ecu as the car is fine with the 1.6 will check engine id on back of block and see if the guy has been telling porkies about it being a 2.0
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
