engine loom
Old Mar 15, 2006 | 11:58 AM
raycov's Avatar
raycov
Default engine loom
ive just got a 2wd cossie shaphire engine loom for rs turbo cossie managment convertion. i can see where everything connects apart from the green,black,and brown and white which are all together and from the same binding there is a red and blue and a red and black, then from another binding there are 2 green which are crimped together and sealed but there is a yellow and black one does it do anything as it dont seemed to be used
Old Mar 15, 2006 | 04:41 PM
jon@work's Avatar
jon@work
ignition amp, amal valve, and ignition coil, by the sounds of it.
see the "engine control diagrams (L1)" on here :
http://www.siipicossu.com/manuaaleja/manuaalit.htm
your loom may not include the "relay for injection system check light" wiring or relay
Old Mar 16, 2006 | 08:20 AM
raycov's Avatar
raycov
cheers mate.
i have found the amal valve wires so they are ethier ignition amp or ignition coil i dont want to appear a thicko but what are the wire colours in english as i dont know a toss about german
Old Mar 16, 2006 | 09:44 AM
SPADGE's Avatar
SPADGE
Green is rev counter feed
Black is the ignition feed
brown/white is the temp gauge feed
red/blue is the live feed to the loom
black/red is the fuel pump feed
greens go to the coil +
black/yellow to coil -
Old Mar 16, 2006 | 11:23 PM
raycov's Avatar
raycov
cheers spadge brilliant
big_Rad
Sep 15, 2017 09:36 AM
Marcus L
Aug 29, 2015 02:18 PM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
