fookin heaters!!!
Old Feb 27, 2006 | 09:31 PM
chris-escort van's Avatar
chris-escort van
Default fookin heaters!!!
hiya i have a 1990 for escort mk4 estate/van and the heaters in my car have randomly stopped working? has this happened to any1 else before or does any1 have any idea wat ois rong???
Old Feb 27, 2006 | 10:39 PM
Moonie's Avatar
Moonie
Blower fan has stopped or no heat through vents?
Old Feb 28, 2006 | 02:08 PM
Billy_RS's Avatar
Billy_RS
fan stopped on mine but is still heating up!!!???
Old Feb 28, 2006 | 03:59 PM
chris-escort van
i have no fan at all so nothin is cumming through did work then it randomly stopped goin go av a look at it????
Old Mar 1, 2006 | 10:51 AM
SafeChav's Avatar
SafeChav
Does it work on the fastest speed? If it does this and wont work on speed 1 or 2 then the resistor pack on the motor has gone.
Other wise, check the fuse firstly, if thats ok its either guna be the switch or the motor itself. Shouldnt cause yout oo much headache they're very simple
Old Mar 2, 2006 | 05:10 PM
chris-escort van
also apret from the fan does any1 know how to remove the front wings as i want sum new1s for wem it goes in for a respray???
Old Mar 2, 2006 | 06:41 PM
SafeChav's Avatar
SafeChav
Thats a nightmare job. They're spot welded on down the tops of the wings, and theres also 2 bits welded by the door hinges. They look shit if you don't spot weld the new ones on IMO, a lot of people drill holes in them and mig weld through it.
Old Mar 3, 2006 | 01:08 PM
chris-escort van
fook it ill have it dun by sum garage or sumfin and if they b*llox it up they can fix it!!!
Old Mar 3, 2006 | 01:09 PM
SafeChav's Avatar
SafeChav
Sounds like a good plan
Old Mar 3, 2006 | 05:25 PM
chris-escort van
ino aaaaa thats exactly wat i thort!!! lol
Old Mar 6, 2006 | 07:55 PM
fordford's Avatar
fordford
it's probably a faulty fuse box,a dry joint ,very common fault mine's the same have run a fused feed from the ignition switch
Old Mar 6, 2006 | 07:58 PM
SafeChav's Avatar
SafeChav
Are you talking MK5/MK6 fuse boxes, MK4 fuse boxes dont have any solder joints and are pretty reliable.
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
