cossie cam timing
Old Jul 25, 2004 | 04:04 PM
pugo's Avatar
pugo
Default cossie cam timing
i am after the cam timing for a pair of bd10's and a pair of bd14's ie how many degrees BTDC and ATDC for each
many thanks in advance
pugo
Old Jul 25, 2004 | 04:32 PM
GARETH T's Avatar
GARETH T
there is no standard timing for these cams
try between 110 to 115 degrees
115 inlet 110 exhaust seems to work
Old Jul 25, 2004 | 08:12 PM
pugo's Avatar
pugo
Default cam timing
i got a bd10 exst and was going to set it 108 btdc and a bd14 inlt which i was going to set at 112 atdc, does this sound ok ?????? or should i delay the inlet cam a bit( to 115atdc), i am not too worried about the bd10 i am more worried that the 14 will hit at hi rpm!!!!
or would you run them both at 110 to 115????
need to know as i am going to time it up 2 morrow!!!!
Pugo
Billy_RS
16
Oct 11, 2025 09:41 PM
RUBY123
Oct 22, 2023 12:04 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
