Excessive Turbo Heat
Old Dec 6, 2003 | 09:27 PM
Default Excessive Turbo Heat
I have a problem of excessive heat coming from my turbo,there is a constant smell of burning rubber too.the bottom of the turbo also has a white powdery coating on it now. local ford garage was no help . I have a 92 4x4 sapphire. Thanks
Old Dec 7, 2003 | 12:14 AM
richm's Avatar
richm
the white powdery coating is probably residue left from traces of coolant leaking from the cooling pipe banjo's.. You will probably never see the leak as it evaporates as fast as it leaks.. If you undo the coolant pipes from the turbo, you'll probably find the aluminium sealing washers are cracked. Nowt to worry about really, but if you do decide to undo them to have a look, make sure you have new replacement washers first They are only pence form Ford, but you will have to fit new ones if you undo them.
Old Dec 7, 2003 | 10:01 AM
Stu @ M Developments's Avatar
PassionFords Creator
As for the burning rubber, just take a quick look and see if some goon has fitted Nyloc type bolts anywhere on the turbo -manifold mountings or exhaust -turbo mountings.
Seen this error before and the nylon inserts stink as they die... lol
Old Dec 7, 2003 | 07:35 PM
thanks very much, can you tell me what the electrical wire is on top of the turbo, i thought that was the one the burning smell was coming from.
Old Dec 7, 2003 | 08:18 PM
THE RADMAN's Avatar
THE RADMAN
are you on about the hego/lambda sensor? this screws into the top of the turbo,about 4 or 5 wires coming off it
Old Dec 7, 2003 | 10:15 PM
yes it could be that it has 2 wires coming out of it i think though.it has a triangular shape connector, whats that for anyway ? new to this coworth business had an xr4x4 before this .
Old Dec 7, 2003 | 10:29 PM
Toe Knee's Avatar
Toe Knee
Check that the turbo return pipe that connects to the sump isnt touching the turbo anywhere as that could be whats bruning!!! Also have u got a heatshield at all?! Cos if not could be the clutch cable or something touching the turbo.
Old Dec 8, 2003 | 06:02 PM
thanks very much for your help ,much appreciated, hopefullly this will be sorted
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
