arp stud and nut kit erst
Old Feb 11, 2006 | 05:30 PM
1905cc's Avatar
1905cc
Default arp stud and nut kit erst
just fitted an arp stud and nut kit to my rst torqued bolts in increments of 20lbft until specified torque of 60lbft was acheived and in correct sequence, it didnt say nething about 90 +90 degree turns tho and wonderd does it need it???? dont want to run my motor yet till i know else h gasket will be f###ed again does anyone know either way??? cheers
Old Feb 11, 2006 | 05:50 PM
jonnyturbo's Avatar
jonnyturbo
standard bolts need the 90+90 turns, i imagine the stud and nut would require the same sequence
Old Feb 11, 2006 | 06:20 PM
SafeChav's Avatar
SafeChav
It will depend whether they are stretch bolts or not.
Aren't ARP bolts re-usable?
Old Feb 11, 2006 | 06:23 PM
jonnyturbo's Avatar
jonnyturbo
good point. but i would check with a specialist before going any further with it.
Old Feb 11, 2006 | 06:53 PM
1905cc's Avatar
1905cc
cheers peeps think they are re-useable just checked on kent cams web site and that said torque to 60lbft using arp molylube didnt mention anything about 90 degree turns so cant need it, need to get my motor runnnin for monday so gonna run it, if h.gasket goes just have to change it again lol thanks again
Old Feb 11, 2006 | 06:58 PM
SafeChav's Avatar
SafeChav
If they are re-useable, they wont need the 90 + 90 cos thats for stretch bolts (stretch bolts being once only) but double check just incase.
Old Feb 12, 2006 | 08:03 AM
cossie604's Avatar
cossie604
lol if they were stretch studs it would sort of defeat the whole purpose of spending lots of beer tokens and fitting them
The reason for using stud and nut kits suchs as ARP's is because under extreme boost standard stretch bolts can......s t r e t c h.....leading to head gasket failure.
Stu.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mc5506
Oct 5, 2015 09:57 PM
little bram
Sep 27, 2015 07:45 AM
