how do you identify a 3 bar map sensor
Old Feb 6, 2006 | 06:25 PM
black3door's Avatar
black3door
Default how do you identify a 3 bar map sensor
hi guys. i recently bought a 3bar map sensor from someone on ebay brand new. since fitting the sensor, the car smokes quite a bit when boosting and over running
turbo is brand new and so is engine (750 miles ago). i have been told that the map sensor could be faulty so i need to find out what numbers identify a 3 bar sensor from a standard 2bar. PLEASE SOMEBODY HELP ME!!!!!!!!
Old Feb 6, 2006 | 06:42 PM
davecosworth's Avatar
davecosworth
IM BACK
hello mate a std 2 bar is black and a 3 bar map sensor is grey sounds like it is faulty tho as i had to work on one that would misfire on boost and then it got even worse and it wouldn't run as it should and it turned out to be the map sensor.
Old Feb 6, 2006 | 07:43 PM
cossie604's Avatar
cossie604
Altho the new batch of 3bar sensors are also black
Old Feb 6, 2006 | 09:02 PM
bud-weis's Avatar
bud-weis
Football Cwazy
presumably you had a 3 bar fitted before??
i think it has aps 05 01 written on it or similar
Old Feb 7, 2006 | 12:56 PM
RICH RS2K's Avatar
RICH RS2K
Sounds like a faulty map check the part number code i had a prob with 1 i bought the code shud be...APSO5/O1..
Pressure sensors MAP
• PRT03/04 - 1bar
• APS02 - 2 bar
• PRT06 – 2.5 bar
• APS05 – 3 bar
Old Feb 7, 2006 | 06:45 PM
Alvyn's Avatar
Alvyn
3 bar map sensor code number ARE APS05/01 batch numbers 0989 may vary! can come in black or grey!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
