Granada cosworth BOA not starting
Hi picked up a Granada cosworth last night ,
Doner for my 3 door,
Right she want ran for 5 years ,
Got it turning over ,
But has no spark ,
I have power to coil pack , ,
Lights on dan but won't turn over by key but if I cross starter she turns freely !
Could this be somthing to do with Alarm?? As under dash there is a grey box stamped ford says CONTR ASY LK & ALARM SYS ?
Any help would much appreciated ! Thanks
But has no spark ,
As I understand it.. (I had a similar problem once and this is what I was told)
Immobiliser will stop power to fuel pump relay/engine management relay.
Maybe you need to check the wiring at the rear end of the car after checking the relays.
I got 12v power to cool pack
I got 12v power to ecu pin 1
I got 12v power to ecu pin 37&57
I got 12v power to 3 greens running off edis module (coilpack)
And got 6v to pin 8 on edis module ,
Have got a green an purple relay witch is in bulkhead passenger side , has engine control on it ,
This has only 1 yellow/black wire coming out of it ,
Then runs into passenger side behind dash to green relay. Witch I suspect is fuel relay ??
The green and purple relay in bulkhead was making funny noises yesterday ,,
rog
Sep 4, 2015 12:10 PM
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
