Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Minimum cossie head thickness????
Old Feb 28, 2005 | 10:48 PM
  #41
Stu @ M Developments's Avatar
PassionFords Creator
frog,
So from the above, a dished piston is better than one that has four little pockets (from a combustion point of view), cos the one with the four pockets would appear "domed" rather than "bowled" ?
No, not quite.
The pockets are a necessity for valve head clearance during maximum lift with some cams such as BD15s etc.
What i am saying, is that if you require a removal of say, 5cc from the piston crown to get the CR you want, instead of literally skimming 30thou of the tops of the pistons, you should have a machine shop machine the tops everywhere so as to retain the original bowl shape and as much of the original height as possible, and thus maintain your original squish clearance. That help?
And yes, one day we will run out of heads
  #42
brad's Avatar
brad
frog if your running wild cams you would need valve pockets tho wouldnt you
oops too slow
Old Feb 28, 2005 | 10:49 PM
  #43
frog's Avatar
frog
0-60 in 17 seconds (eek)
Yup - purrfect.
Old Feb 28, 2005 | 10:50 PM
  #44
frog's Avatar
frog
oops too slow
Agreed but doesn't that tend to make the piston look more domed overall ? Thus creating the pockets stu was on about ?
  #45
dave cos4x4's Avatar
dave cos4x4
Stu,
i had my head work done by a bloke called Adrian.
has a head shop called 'Impulse Developments' in Todmorden.
he was talking about this a while back and i believe he may have experience in this.
thats whty i mentioned it.
Dave.
Old Feb 28, 2005 | 10:53 PM
  #46
richm's Avatar
richm
  #47
You can see the piston shape here if it helps you to imagine how the outer edge is raised to effectively "Funnel" the mixture to teh middle as it reaches TDC.
If your pistons end up down the bore when sat at TDC, the tops have had a lot removed from them. A Std squish has teh piston 20thou above deck height.
Edited to say, thats a crap picture actually, too much glare
Old Feb 28, 2005 | 10:57 PM
  #48
frog's Avatar
frog
It's pretty clear on that picture stu, but the pockets look quite small. I am sure I have seen pistons with pockets so deep they almost looked like the piston had a domed overall shape.
Anyway that's not really important - I am not too sure why I am labouring the point
Old Feb 28, 2005 | 10:58 PM
  #49
brad's Avatar
brad
so basicly , the edges of the piston ideally should be kept as close to standard height as poss and the bowl machined down as evenly as poss across the width of the original bowl or am i gettin confuddled ?
Old Feb 28, 2005 | 11:00 PM
  #50
frog's Avatar
frog
Brad, that's how I understand it
Old Feb 28, 2005 | 11:01 PM
  #51
Heres a better pic of the piston shape and squish area...
And a lone piston being weighed and logged.
These should give you an idea how squish works, purely by their shape, now you are thinking about why they are shaped as they are
Old Feb 28, 2005 | 11:02 PM
  #52
brad's Avatar
brad
we are probably both being thick then
Old Feb 28, 2005 | 11:03 PM
  #53
Yes, exactly that Brad, unless you have good reason for lowering the squish area, such as higher expansion piston materials or use of a centralised gudgeon pin where you had an offset one before (Piston rocks at TDC in this configuration )
  #54
frog's Avatar
frog
Stu, just thinking about it all again, I am not sure we talk about the same thing when we talk about decompression plates...
If I understand correctly, when the head is skimmed, it looses a given amount of metal, and the overall depth of the "combustion area" in the head reduces. A decompression plate as I understand it, would recover this depth loss.
Is that what you were on about too ? Cos I can understand how it affects the squish area, but it only brings it back to where it was before the skim
Old Feb 28, 2005 | 11:13 PM
  #55
brad's Avatar
brad
so the chamferd (sp?) edge on the piston bowl keeps the explosion away from the block/head walls and directly underneath the valves in an evenly spaced area helping to avoid hotspots in the squeeze area .
Old Mar 1, 2005 | 12:06 AM
  #56
Karl's Avatar
Karl
Norris Motorsport
Before everyone discards their over skimmed heads, I can fully weld the entire head face and remachine the entire face, water ways and chambers to restore the head to as new!!!! It is'nt cheap but it does give new life to an otherwise scrap head!
I can of course recess valves and tip the valve stems for those heads that are around the 138.5mm area, but anything much below that needs the above welding work!
Old Mar 1, 2005 | 01:31 AM
  #57
Fastmaul's Avatar
Fastmaul
K155MYRS
Well good to Know that Karl can do this! now if he was only in my area.
Old Mar 1, 2005 | 03:56 AM
  #58
PAUL V's Avatar
PAUL V
Karl Will Not tig welding make the head soft ?? With the heat you put into it ?
Old Mar 1, 2005 | 06:51 AM
  #59
xr4x4rs's Avatar
xr4x4rs
dont want t sound thick but im interested in how you measeure the head
i mean where would you measure the depth from
would it be from the back of the head from centre of the top to the mating surface of the bottom
obviously digital vernier to do this
as im getting worried now that my head may be scrap and getting the engine built soon
Old Mar 1, 2005 | 07:04 AM
  #60
brad's Avatar
brad
i think it is measured from top face (cam side) to bottom face . has to be measured in a few places to make sure its the same thickness all over
Karl , what does it cost to get the meat put back on the head ? are there any downsides to having it done ?
Old Mar 1, 2005 | 07:48 AM
  #61
Karl's Avatar
Karl
Norris Motorsport
PJ,
The method I use involves stress relieving the head during the welding process as well as having the head pre heated(I don't want to say what I do as thats giving the game away) but it results in a very hard head face and is totally reliable.
Old Mar 1, 2005 | 09:56 AM
  #62
Whilst the decompression plate will restore lost compression, it will by its very nature still increase the squish clearance by raising the cylinder head itself to a higher plane and as such is undesireable.
Old Mar 1, 2005 | 10:37 AM
  #63
frog's Avatar
frog
I understand that would be the case if the head was raised higher than the amount of removed material.
If say, 0.5 mm had been removed from the head, and the decompression plate was that same thickness, would it affect the squish area as you suggest ?
Old Mar 1, 2005 | 10:54 AM
  #64
Yes.
The diagram above may help to show how a spacer plate will move the heads squish area upwards away from teh pistons, thus increasing the squish clearance.
Does that help?
Old Mar 1, 2005 | 10:58 AM
  #65
It's Czech Mate's Avatar
It's Czech Mate
Best thread on here for ages. I'v often wondered about skimming and it's effects. Never knew about squish. Top work to Stu and Karl and everyone who asked good questions. This is what makes the site brilliant for me
Old Mar 1, 2005 | 11:00 AM
  #66
frog's Avatar
frog
mmmm, not sure I do get it....
Would that be because the head isn't actually flat in that area, again, helping to concentrate the fuel mixture as close to the plug tip as possible ? A decompression plate would raise the head, but in a straight up direction, therefore not reproducing the slope in the head's combustion area ?
Old Mar 1, 2005 | 11:15 AM
  #67
St3V3_C's Avatar
St3V3_C
Yes.
The diagram above may help to show how a spacer plate will move the heads squish area upwards away from the pistons, thus increasing the squish clearance.
Does that help?
Cool thread
So are the cylinder holes completely round in these plates? I am guessing so, then I understand the problem.
If they had the same shape as the head, would that make it all OK?
Old Mar 1, 2005 | 11:18 AM
  #68
frog's Avatar
frog
Steve, I guess the decomp. plate is just like a thick gasket, so all the edges are square, hence my question above.
Strange how an innocent question turns into this
Old Mar 1, 2005 | 11:58 AM
  #69
brad's Avatar
brad
its like rocket science , explained in laymans terms for us simple people
Old Mar 1, 2005 | 12:40 PM
  #70
richm's Avatar
richm
Just as an 'interesting' aside...
I used to do a bit with Talbot Avengers and Sunbeams - the 1.6 pushrod engine has half the combustion chamber in the cylinder.. the piston stops well short of the block deck, absolutely no squish area whatsoever! They can make fair power (in their day anyway) but the ignition advance curve to achieve it is wild - ours had max advance of 48 degrees!
Old Mar 1, 2005 | 12:49 PM
  #71
Karl's Avatar
Karl
Norris Motorsport
Indeed Rich, in essence the more efficient a combustion chamber design the lower the required ignition for MBT conditions. (MBT = minimum spark advance for best torque). This ultimately comes about by two main factors, these being spark plug location in the chamber and the chamber design and size.
Strangely though the effect on potential bhp has little to do with chamber design. It's all about efficiency for fuel economy and emissions these days!
Old Mar 1, 2005 | 12:59 PM
  #72
wes's Avatar
wes
The decomp plate will increase the space between the top of the piston and the squish area in the cylinder head, in the 1st pic, they are very close together:
Adding a decomp plate now makes them further apart, so not "squishing" the mixture as much as it should do:
**this is my understanding of what has been said in this post**
Old Mar 1, 2005 | 03:38 PM
  #73
A bit busy now but I will turn my attention back to this post tonight chaps
Old Mar 1, 2005 | 05:38 PM
  #74
rs4steve's Avatar
rs4steve
PJ,
i have just had my head repaired must have used this process was also told will not have to pay the bill until engine is back in the car totally happy with the results after mapping, must admit andy fisher was a bit sceptical about this head repairing process
cheers steve
Old Mar 1, 2005 | 05:42 PM
  #75
frog's Avatar
frog
Here's how I understand it...
In the picture above, the decomp. plate only replaces the same amount of material that was removed by the skim(s).
However, because the walls of the plate are vertical, the squish area has changed shape.
Over to you stu...
Old Mar 1, 2005 | 06:24 PM
  #76
Ginge !'s Avatar
Ginge !
just finding my feet
see this is gonna turn into the mapping thread that i nolonger understand and so i nolonger read it
im with stu so far but thinking the same was as frogs explanation
Old Mar 1, 2005 | 06:47 PM
  #77
richm's Avatar
richm
Over to you Stu...
The issue is frog, that the decompression plate will usually have circular bores rather than the same shape as the chamber face with the two D-shaped flat areas (which are in fact the squish areas), this leaves a gap the thicknes of the plate between those flat areas of the head and the piston crown raised areas, hence the squish clearance increased by the plate thickness.
Old Mar 1, 2005 | 06:48 PM
  #78
brad's Avatar
brad
when we talk about skimming a head , we are only talking about .0000eleventy millionth of a gnats cock , surely a thin flimsy bit of metal cant be a good idea aswell as a head gasket
Old Mar 1, 2005 | 06:50 PM
  #79
ImaRacing 700's Avatar
ImaRacing 700
With YB's people worry too much
Look at it this way...a STD 4x4 or 2wd YB can take 400bhp no bothers...a 4x4 can take 500bhp no bothers...who gives a fook about height of head..especially in a sub 400 engine!!!
Old Mar 1, 2005 | 06:56 PM
  #80
richm's Avatar
richm
400bhp is fook all use to anyone when there's a valve seat sat on top of the piston Phil..
