Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
det...
Old Oct 29, 2003 | 03:54 PM
AlexF's Avatar
AlexF
Default det...
Ok I know theres been loads and loads of threads on this in the past but I just wanted to know the answers to a couple of questions...
In high speed/high load situations... can you hear it?
Are there any symptoms, or is it all over too quickly?
Alex
Old Oct 29, 2003 | 03:56 PM
Jim Galbally's Avatar
Jim Galbally
from what i rememeber from various essays...
det is not the same as pinging
pinging is easily audiable
det is not
det must still be audiable but i presume its impossible to hear inside the car without detcans
i stand to be corrected tho...
Old Oct 29, 2003 | 03:59 PM
EscortWRC's Avatar
EscortWRC
Detonation and pinging ARE the same thing
Old Oct 29, 2003 | 04:01 PM
Jim Galbally
ok well high speed detonation and pre-ignition then...
AlexF's Avatar
AlexF
jim is trying to say there is a difference between pre-ignition (too hot a plug for example) and uncontrolled burning of end gasses....
Alex
Old Oct 29, 2003 | 04:03 PM
Porkie's Avatar
Porkie
I always though it was pinking, not pinging....
Old Oct 29, 2003 | 04:04 PM
GARETH T's Avatar
GARETH T
i think in usa they call in pinging,, as i have seen it wrote like it in a few books
Old Oct 29, 2003 | 04:05 PM
Jim Galbally
i think the term is pinging and people incorrectly pronounce it as pinking...
i mean... what's pink about it?
also which is the 1 with the 2 flame fronts meeting and which is the one where the burn hits the piston on its compression stroke?
Old Oct 29, 2003 | 04:08 PM
Stu @ M Developments's Avatar
PassionFords Creator
Oohhh... Now heres an essay post...
Wonder if i can find one of the ones ive already done?
porkie,
In the UK it is "Pinking" but much as i hate to admit it, our American friends actually got it right with "Pinging" as thats what it sounds like.. ping, ping..
We just missinterpreted it as usual.....
Old Oct 29, 2003 | 04:09 PM
AlexF's Avatar
AlexF
det is pinging in american terms... different terminology.
Jim what are you on about? two flame fronts?
Preignition is when the burn is started before the spark plug is fired... ie there is another source of ignition. Det is where the end gasses are heated by the combusiontion process to the point where they self-combust due to pressure and temp difference rather than being ignited by the advancing flame front.
Alex
EscortWRC's Avatar
EscortWRC
Well......
the burn ALWAYS starts on the compression stroke if you are timed BTDC...that is the whole point.
Detonation is ignition OTHER than when you want it. This can be due to local hot spots, low octane fuel, etc....
I've always called it pinGing but then again, I don't speak the queen's English either
Old Oct 29, 2003 | 04:15 PM
AlexF's Avatar
AlexF
anyways...
the question is CAN YOU HEAR IT?
Are there tell tail signs before melt down?
Alex
Old Oct 29, 2003 | 04:16 PM
PJay's Avatar
PJay
the queen's English
Wats dat then?
Old Oct 29, 2003 | 04:18 PM
GARETH T's Avatar
GARETH T
Detonation occurs in the combustion process when the advancing flame front, which is pressurizing and heating the unburned mixture ahead of it, does so at such a rate that unburned fuel in that zone achieves its auto-ignition temperature before the arrival of the actual flame front. The result is that the unburned mixture combusts "spontaneously" and over the entire zone where the auto-ignition temperature has been achieved. The apparent flame speed in this zone is many orders of magnitude faster than that in conventional combustion initiated by a normal flame front, with the result that the local rise of pressure and temperature is significantly sharp. This produces the characteristic "knocking" or "pinking" sound, and the local mechanical devastation that this can produce on piston crown or cylinder head can be considerable. Actually, "knocking" is the correct terminology for what is a really a detonation behavior over a small portion of the combustion charge. A true detonation process would be one occurring over the entire compressed charge. However, because detonation in this strictly defined sense does not take place in the spark-ignition engine, the words "knocking" and "detonation" are used interchangeably in the literature, without loss of meaning, to describe the effects just discussed.
Old Oct 29, 2003 | 04:24 PM
GARETH T's Avatar
GARETH T
yes with a par of these and a small bore pipe!
or buy using this:
here
Old Oct 29, 2003 | 05:13 PM
AlexF's Avatar
AlexF
u get over excited there gareth? hehehe
cheers for the link
Alex
Old Oct 29, 2003 | 05:16 PM
Hi,
This one will require an essay, and if its still required later il do one.
Detonation and pre ignition are two seperate entities IMO.
Pre ignition can be heard in "most" cases.
Detonation is very much harder to detect by ear and requires a listening device to localise it.
Old Oct 29, 2003 | 05:18 PM
Fagin's Avatar
Fagin
When my first Escort Cossie let rip at about 150mph (on speedo), I never heard anything. The first thing I knew was a slight miss, then another one and then oil over the windscreen and a plume of smoke across the whole mway!!!
It all depends on what kind of speed you are doing as regards to when the DET happens, to whether or not you can hear it. (just read stu's post, so I have my Det and Pre-ign confused! )
Everytime I get anything like a missfire at high revs, my arse always goes in to overdrive!
Old Oct 29, 2003 | 05:21 PM
Fagin's Avatar
Fagin
And even then most people wouldnt know what they are looking for!
Old Oct 29, 2003 | 05:26 PM
Yeah....
They want to be listening, not looking....
Stick to computers Shaun
Old Oct 29, 2003 | 05:30 PM
GARETH T's Avatar
GARETH T
Old Oct 29, 2003 | 05:40 PM
Fagin's Avatar
Fagin
Fraudulent slip there!
Old Oct 29, 2003 | 05:43 PM
RichardPON's Avatar
RichardPON
Originally Posted by GARETH_ESCCOS
We just bought that set - top stuff
Old Oct 29, 2003 | 05:44 PM
Watch that brown hole tonight mate...
Dont want to see you at work with a big slap mark on your face cos of another fraudulent slip
Old Oct 29, 2003 | 05:45 PM
EscortWRC's Avatar
EscortWRC
I think you mean 'Freudian slip'.......
Old Oct 29, 2003 | 05:46 PM
GARETH T's Avatar
GARETH T
cool as
Old Oct 29, 2003 | 05:48 PM
Fagin's Avatar
Fagin
If that means "I fooked up", then yes!!!
Old Oct 29, 2003 | 05:50 PM
He did... bit i didnt want to pick on him twice.. that would be bullying
Old Oct 29, 2003 | 06:58 PM
Billabong's Avatar
Billabong
I see Stu's developing an Inspector Clouseau style French accent....
Old Oct 29, 2003 | 07:00 PM
GARETH T's Avatar
GARETH T
well spotted bill
Old Oct 29, 2003 | 07:21 PM
RichardPON's Avatar
RichardPON
I just spotted that too - AROFLMFAO
Old Oct 29, 2003 | 07:36 PM
Damn... whats the score now then Bill.. i forgot
Old Dec 12, 2003 | 06:58 PM
Pinking is called pinking because it sounds like "pink pink pink" - ping is something different
Old Dec 12, 2003 | 06:59 PM
no they are not.
Pink/ping ing you can hear. DET you cannot, not even with DET Cans.
Old Dec 12, 2003 | 07:21 PM
Billabong's Avatar
Billabong
Detonation = shock waves which can be picked up with the correct equipment. Don't understand what you are getting at Steve
Old Dec 12, 2003 | 07:35 PM
Can they, speak to someone who Builds engines from scratch and ask them...
Not tuners, engine designers.
Not sure its detectable.....with any equipement we can buy....
Old Dec 12, 2003 | 07:37 PM
Knock sensors pick up pinking and engine noise, not det.
Old Dec 12, 2003 | 07:39 PM
Billabong's Avatar
Billabong
Well, I haven't enough knowledge to argue that one, lol.....but how can you engineer for something that is undetectable?
Old Dec 12, 2003 | 07:44 PM
how is det engineered.. ?
Old Dec 12, 2003 | 07:55 PM
Billabong's Avatar
Billabong
I meant 'engineered to avoid detonation'
Detonation can be caused by either excessive temperature or excessive pressure of the fuel-air charge. Take that for granted - but how can you engineer a motor not to det' if you can't actually detect when you have reached the point of detonation? I mean you can obvioulsy ensure that cylinder head temp's etc are kept within tolerance, but if you cannot detect it, you don't know what the tolerances are....
