Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Problem with cossie agen.
Old Feb 25, 2010 | 07:10 PM
chriscossie's Avatar
chriscossie
Unhappy Problem with cossie agen.
hello people can anyone tell me why my car is over fuelling as it f??king smells so rich and black smoke coming out of the exhaust.and you cansmell fumes in the breather system.and the water looks yellow ruste colour with like a oil film could it be the fuel pressure regulator seized open as the car has not been run for 3 years as i have rebulid the car.
thanks chris.
Old Feb 25, 2010 | 10:30 PM
COLEYST200's Avatar
COLEYST200
it could be the map but as you said the car has been rebulit have you got it all piped right and is the setup the same as befor the came of the road
Old Feb 25, 2010 | 11:44 PM
fezzy240bhp's Avatar
fezzy240bhp
take it out for a long steady run and see if it clears up dont boot it cause ur just adding more fuel ! if this does not work get it looked at and maybe try a service !!
Old Feb 27, 2010 | 06:46 PM
t4 and greys's Avatar
t4 and greys
cosworth gimp
try changing your Coolant Temp Sensor (blue sensor located at rear of head inlet side by dipstick)
could be faulty and causing your issues !!
worth a go for the price of a new sensor
Old Mar 15, 2010 | 06:59 AM
i would also try a water temp sensor. The same thing happened to my cossie. The sensors are only 20 quid from MSD.
Old Oct 11, 2010 | 12:45 PM
martysmartie's Avatar
martysmartie
I would first check/replace the CTS (Coolant Temperature Sensor) these go out of range after a while and is the main factor used for fueling for the base level of fuel injected right from zero degrees to boiling, if this is giving a duff reading I.E colder than it is the ECU will fuel accordingly.
Martin
Old Jan 15, 2011 | 11:33 PM
TieMyShoe's Avatar
TieMyShoe
does anybody have the voltage specs for the sensors?
Old Jan 16, 2011 | 02:54 PM
martysmartie
The CTS reads works on a 0-5V scale, I only know the resistance VS temp scale but it should be nearer 5V at cold with the voltage dropping with the engine warming up.
Martin
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
