Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Can anyone post up a guide
Old Oct 6, 2009 | 01:07 PM
RSTurboSI's Avatar
RSTurboSI
Default Can anyone post up a guide
i'm in need of a guide, Ive not done a head rebuild in a long time, and would like to make sure i do everything correct.
That would be for a MFI head, S2.
Going from built, to removed, to refitted, such as removing the cams, lifters, tappets without removing the head.
Old Feb 3, 2010 | 09:39 PM
kermitt's Avatar
kermitt
Here you go dude, just used this myself;
http://www.rsownersclub.co.uk/rsocbb...d.php?t=194777
Make sure you check both timing marks are at TDC before re-fitting the head and that once you have tensioned the timing belt and the rotor is pointing to point 1 on the dizzy otherwise it may not fire up (as I found out!)
Steve Cooper
Sep 15, 2015 04:39 PM
Flateric_2002
Sep 15, 2015 08:41 AM
