Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Fitting a cam cover mounted phase sensor to a YB
Old Apr 30, 2006 | 10:43 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Default Fitting a cam cover mounted phase sensor to a YB
Having converted to coilpacks i decided to completely remove the dizzy. Removing the dizzy meant moving the phase sensor to the cam cover Grp A style. The removal of the dizzy required an oil pump drive as well.
Firstly i made an oil pump drive by cutting the dizzy in half and machining the shaft to take a bearing
Then made a housing to fit in the block
Then pressed the two bits together
To give
And finally fitted to the engine
To fit the phase sensor in the cam cover you need to machine the cover to take the sensor holder
I then got the sensor, holder and phase sensor trigger. Available from Mountune or Zoo.
The sensor and holder fitted to cam cover
The cam requires machining to take the trigger
Thanks to Martin@Reyland for that bit of machining
The trigger then bolts into the end of the cam
Next update will be the timing of the phase sensor to the cam and final fitting of the cam and cover.
Old Apr 30, 2006 | 10:58 PM
CosRush's Avatar
CosRush
Excellent work .
If all posts were like this we'd all be learning more....
Old May 1, 2006 | 10:04 AM
trevCOSS's Avatar
trevCOSS
looking good, cant wait to do the same to mine.
Old May 2, 2006 | 02:05 PM
Excellent post
Old Jun 2, 2006 | 07:40 PM
THE RADMAN's Avatar
THE RADMAN
very good ive always wanted a lathe
Old Jun 5, 2006 | 10:54 AM
Franco's Avatar
Franco
Has is been timed yet Rich??
Old Jun 5, 2006 | 10:58 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Old Jun 13, 2006 | 01:23 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Not yet mate, just waiting for the outcome of my oil pump fiasco before i re-time the engine back up with a new belt+tensioner.
Old Jun 16, 2006 | 11:41 AM
Franco's Avatar
Franco
Richie,
Did you machine the cover for the sensor, if so were the schematics supplied with the kit?
Also why did you give the cam to martin to machine? by all accounts you're more than skilled for the job?
Really going to be interested to how this is timed up!!
Old Jun 16, 2006 | 11:42 AM
Franco's Avatar
Franco
Richie,
Really going to be interested to see how this is timed up!!
Old Jul 31, 2006 | 01:03 PM
Franco's Avatar
Franco
Tick tock tick tock tick tock!
Old Oct 20, 2006 | 04:39 PM
Franco's Avatar
Franco
Well i for one know this engines finished!
So finish the post slacker!!
Old Oct 25, 2006 | 09:36 PM
july1's Avatar
july1
I guess you've add the bolt on top to help the removal?
Old Oct 28, 2006 | 05:59 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Will be taking some photos next weekend Jase when i remove the cam cover for powder coating
Yes mate
Old Nov 5, 2006 | 09:29 AM
marco polo's Avatar
marco polo
spot on richy
good work mate
Old Dec 31, 2006 | 05:03 PM
trevCOSS's Avatar
trevCOSS
come on rich you should have finished this by now
Old Jan 24, 2007 | 12:08 PM
WD Pro's Avatar
WD Pro
Hi B9 Kos,
Could you give me the dimensions of the silver bung (with the o ring around it).
I need to make one as I dont need the dizzy or the oil pump drive.
Cheers,
WD
Old Feb 10, 2007 | 08:40 PM
stevieturbo's Avatar
stevieturbo
C**t
Does anyone sell this complete kit of parts for doing this conversion ?
Old Mar 30, 2007 | 11:54 AM
WD Pro's Avatar
WD Pro
Just got my sensor and was wondering about the clearance it needs to run properly :
The cam extension lobes - fixed height.
The mounting flange - fixed thickness.
The rocker cover thickness - variable depending on refurbs etc
Should I put a washer between the sensor and mounting flange to put it back to 'approximatley' it's design height.
Cheers,
WD
Old Mar 31, 2007 | 08:20 AM
july1's Avatar
july1
According the GpA manual your are supposed to 'clean' the peint on the cam cover and fit shims between the houssing and the cover (not between the sensor and the housing) better if you have to change quickly the sensor between two stages but for us I guess it doesn't make a big differance as long as you have the correct gap
I'm waiting my new cams to machine the whole things to do the same
Old Apr 3, 2007 | 03:56 PM
WD Pro's Avatar
WD Pro
Does anyone know what the correct gap is ?
I had approx 0.5mm less gap then the length of sensor. I put a 1.00mm washer between the sensor and housing so I now have approx 0.5mm clearance.
Based on the crank sensor spec this is OK but is it also OK for the cam sensor ? I guess the cam sensor could cope with quite large clearances as the magnet in it is really stong (compared to the crank sensor) and the lobes it talks to are also bigger
Old Apr 3, 2007 | 04:41 PM
july1's Avatar
july1
the gap it needs to be set at 0.015" to 0.018" (0.38 -0.46mm) so you're a bit far but I guess it will work anyway
Old Apr 4, 2007 | 11:44 AM
WD Pro's Avatar
WD Pro
Ta
Old Oct 15, 2009 | 02:34 PM
wildo105e's Avatar
wildo105e
Originally Posted by WD Pro
Hi B9 Kos,
Cheers,
WD
Looking to make one myself i am sure i can work out dimensions but what does the cap head screw do on the top. I assume the bearing is a press fit etc.
Many thanks
Old Oct 15, 2009 | 08:00 PM
Would be a lot easier to use the jackshaft pulley than the cam itself for the phase.
Old Jul 19, 2010 | 01:58 PM
Captain Cotswold's Avatar
Captain Cotswold
.. For later'rs
Old Jul 11, 2011 | 10:03 PM
andy escos's Avatar
andy escos
Many thanks
to get the dimensions to make your own oil pump drive just pull your dizzy out & measure it .
the cap head screw is there purely as a means for getting the oil pump drive out again ,i.e. undo bolt grab with pliers & pull .
ps i know this is a old thread but it still needs more information to complete this conversion .
pps i do not need the info as i already done my car but i have been asked by pm but i can not remember it all .
Old Aug 14, 2011 | 04:53 AM
RSescorts's Avatar
RSescorts
This is helpful, but is there any other guides on this more uptodate?
got my cam cover cut,
need to machine the cam for the trigger.
cheers
Ken
Old Nov 28, 2011 | 09:07 PM
Rsmat's Avatar
Rsmat
Awesome mate cheers.
RUBY123
Oct 22, 2023 12:04 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
muz
Aug 16, 2015 12:57 PM
Zoggon
Aug 10, 2015 10:39 AM
