My 3dr Breaking - updated 1/12/08
Old Oct 12, 2008 | 08:58 PM
rsnissan's Avatar
rsnissan
Default My 3dr Breaking - updated 1/12/08
Welcome to the rsnissan auto jumble i will update this thread with new bits as i break the car further.
Standard Coil £10
Grp A leads only a few K's use £70
Standard Beru leads £40
Dizzy + phase sensor £20
Turbo Oil Feed pipe including adaptor £20
valve Stem oil Seals £40
Tappets Genune INA £40
PAS pump + Brackets £40
Polished stat housing and stat with take off for water temp gauge £30
Stainless lifting eyes £20
Water pump £30
TPS PFR8 £30
Mint Crank sensor £15
pics available on request for the above bits
FULLY aeroquiped breather £250
with welded on - 12 fittings going to both sides of the block with the correct adaptors to screw into the block on the exhaust side and push fitting to fit ion the inlet side and replace the kidney flame trap
Also a vent to atmosphere and a -10 return to sump (again proper threaded fitting)
Powder coated in a hard wearing "eggshell" finish black
3dr Header tank and swirl pot £150
With aeroquiped -4 for the swirl pot, a -4 blank (can be removed for water feed to turbo) and including a mint (rare) 3dr water level sensor also comes with roose motorsport hoses from rad to Stat housing and from the rad to swirl pot comes with brand new black cap, finsihed in black again eggshell finish
Washer bottle £75
With cap, level sensor (rare) and pump finished in black eggshell finish
PAS Tank £75
comes with new cap and finished in black eggshell finish powercoat
324mm Big brake conversion £500
Using 911 C2/Boxter S calipers been, Freshly refurbed and in porker boxes with brembo blanking plugs.
Brand new porker OE pads, retainers, pins, backing plates, mounting bolts
Brand new Focus RS OE Brembo discs. All that is required to fit these is a bracket (just knock one up in wood and get a machine shop to make for you) and some hoses to connect.
Grp A Throttle Bracket SOLD
Samco bottom water hose in Black £20 (bottom one in this pic)
Full Samco boost set inc stainless boost pipe £100
Early 2WD head needs an exhaust valve £350
includes everything apart from cams and tappets (can be supplied at cost)
Pair of BD10's £120 the pair
GL Spec Lamps SOLD
Chrome cam cover 2wd with breather take off £70
Turd coloured cam cover with breather take off £60
2wd Flywheel dont think this has been skimmed but can measure £60
2WD Engine Arms £20
Powdercoated cam pulleys £40 as above
ISCV £45
2wd throttle body inc idle screw £45 as above
black collins -31 actuator £40
2WD FPR £20
Old Oct 12, 2008 | 09:08 PM
magentasafchris's Avatar
magentasafchris
Oh why o why when i'm skint
Old Oct 12, 2008 | 09:46 PM
Barry R's Avatar
Barry R
Right i need the following please:-
1x rubber engine mount
door panel screws
metal water pipe at bottom of rad
fan switch plug with about 2" of wire left on
rad mounts
circlip that holds the speedo cable to gearbox
drivers outer door window seal
both front kick plates
thats if your breaking fully
Old Oct 12, 2008 | 09:58 PM
boXXer's Avatar
boXXer
GASH!
shit man
what ya gunna do with front bumper/splitter?
Old Oct 12, 2008 | 10:22 PM
AndyPen's Avatar
AndyPen
Hi Andy,
I fitted a new lower spoiler last year - same tape was on it mate so proper pucka
Whats the deal on the upper spoiler mate? If it isn't gone can you pm me pls?
Old Oct 12, 2008 | 10:23 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
another to the slaughterbut i can understand your just trying to get some of you money back
Old Oct 12, 2008 | 10:27 PM
col cos1's Avatar
col cos1
price on upper spoiler and front bumper if rs500 mate
Old Oct 12, 2008 | 10:44 PM
RSCossieGaz's Avatar
RSCossieGaz
oh its so sad to see her coming apart!!
had a glimpse of the 3dr today and what a beaut'
Old Oct 12, 2008 | 11:15 PM
rs_cos's Avatar
rs_cos
3 door resto in progress
do you want to sell the upper spoiler aswell. cheers charlie.
Old Oct 13, 2008 | 12:02 AM
rsnissan's Avatar
rsnissan
door panel screws
rad mounts
I'll let you know when I get that far mate, gonna try and do in in some sort of order, TBH I would think most of the small bits will go other along with other main parts but i'll let you know.
Originally Posted by boXXer
shit man
not sure if the bumper will go with the car or not yet, splitter will go separately if you want if.
Originally Posted by AndyPen
Hi Andy,
Cool nice to get that confirmed mate
someone is interested already if they dont want it i'll stick it up for sale in this thread.
as above mate front bumper is standard 3dr
i'll let you know
Old Oct 13, 2008 | 02:35 AM
CRAIG HAYTER
how much for the ariel pleaseand the front splitter could you pm me
Old Oct 17, 2008 | 12:41 AM
CRAIG HAYTER
how much for the ariel please?
Old Oct 17, 2008 | 12:45 AM
LINCOLN's Avatar
LINCOLN
Will have the grills if you post to Australia - post code 3081.
Old Oct 17, 2008 | 06:11 AM
MARCOSWORTH's Avatar
MARCOSWORTH
YHPM Andy
Old Oct 19, 2008 | 10:09 PM
rsnissan's Avatar
rsnissan
more stuff added
Old Oct 19, 2008 | 11:07 PM
CRAIG HAYTER
Old Oct 19, 2008 | 11:13 PM
RSCossieGaz
andy i'll have the k&n cone filter will take it off you!!
Old Oct 20, 2008 | 07:44 AM
3dr cossie's Avatar
3dr cossie
how much for the front spoiler posted?
cheers matthew
Old Oct 20, 2008 | 09:16 AM
rsnissan's Avatar
rsnissan
Ariel is not for sale just yet mate.
ok mate............do you rememebr when i bought it
cheers matthew
I have sent you a PM mate
Old Oct 20, 2008 | 11:05 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
what size are the spokes in your signature, are they going ?
Old Oct 20, 2008 | 04:16 PM
cossieprob's Avatar
cossieprob
550+ LUV IT!!!!!!!!!!!!!!
How much 4 the cxn wheels
Old Oct 20, 2008 | 04:26 PM
rsnissan's Avatar
rsnissan
Wheels should be going this week..................the amount of interest I've had in these I reckon I could have sold them 10 times over now
Old Oct 20, 2008 | 05:27 PM
cossieprob's Avatar
cossieprob
Bugger id love them on my 3 door, if they dont go pm me. Out of interest what size r they and what r they new . thanks
Old Oct 20, 2008 | 05:52 PM
rsnissan's Avatar
rsnissan
I cant believe the interested to be honest..............
wheels were approx 2200 inc everything. 9x17 on the back 8x17 on the front.
I read somewhere that the dont make the same style anymore (the new ones have less spokes i think) so maybe thats why
Old Oct 20, 2008 | 06:08 PM
cosworth007's Avatar
cosworth007
breather with hoses?
Old Oct 20, 2008 | 06:34 PM
cossieprob's Avatar
cossieprob
The old one where 20 spokes, now they r 15 i think im wright , got 2 get a set cheers
Old Oct 20, 2008 | 06:42 PM
cossie604's Avatar
cossie604
Im not as keen on the new style of cxn wheel...much prefer the older ones like rsnissan has sold.
Anyhows....you got me the details as to where I can send this here £3150 to fella?
You've got a few other bits and bobs that im interested in but i'll have to wait till payday (hoping those bits aint sold by then) so the missus doesnt notice my bank account dropping too much in one go
Old Oct 20, 2008 | 07:21 PM
cosy trav's Avatar
cosy trav
have you got the rear quarter window trims for sale ?
Old Oct 20, 2008 | 08:46 PM
grsford's Avatar
grsford
pm'd
Old Oct 20, 2008 | 08:54 PM
RSCossieGaz
andy i could be spending some money with you when i get paid
Old Oct 20, 2008 | 08:55 PM
RONNIE AMIS's Avatar
RONNIE AMIS
hello mate i'll have the accelerator cable bracket if you've still got it mate?
Old Oct 20, 2008 | 08:58 PM
RONNIE AMIS
what you doing with the fuel rail and quip mate?
Old Oct 20, 2008 | 09:08 PM
marco polo's Avatar
marco polo
my god andy i never thought you would break it mate shame really it is a good car very near copy to mine ....lol...
i suppose things happen i can understand tho there are some very good parts on it
good luck
marco
Old Oct 20, 2008 | 09:34 PM
bad boy rs's Avatar
bad boy rs
pmd you fella
Old Oct 20, 2008 | 09:35 PM
TiB's Avatar
TiB
How much for the plastic bulk head panel please?
Lee
Old Oct 21, 2008 | 07:13 AM
Mr RS500's Avatar
Mr RS500
Andy
do you know anyone going to the RSOC AGM this weekend , if you do and you still have it i will have the carbon 500 front splitter , but i wouldnt risk posting it so if you can get it to the AGM i can collect and pay cash
Paul
Old Oct 21, 2008 | 07:27 AM
rsnissan's Avatar
rsnissan
BTT more stuff added, will get back to everyone above later on this AM.
Old Oct 21, 2008 | 08:28 AM
J9BBY's Avatar
J9BBY
First dibs on SECS monitor please. PM sent.
Old Oct 21, 2008 | 09:53 AM
rsnissan's Avatar
rsnissan
Not breaking the shell just yet mate
ok no worries
list ammended now mate
good luck
marco
yeah I know, just dont use it as much as I used to now mate i remember looking at yours before I got mine and I knew EXACTLY how i wanted mine to be after that no where near as "propper" as yours is though where it counts though
Lee
I'll have to let you know when I get down to the shell mate
Originally Posted by Rs500 Registrar
Andy
Paul
I'll find out and get back to you mate
I've PM'd you mate
On another note someone else PM'd and has a full mailbox..........
kaisersolsay has exceeded their stored private messages quota and can not accept further messages until they clear some space.
Old Oct 21, 2008 | 10:33 AM
carlo's Avatar
carlo
you have pm
