(COLEYST200) focus to focos / skyline gear box
Old Jul 18, 2017 | 08:41 PM
  #2841
I can't see the pic where I am but are you going to make it big wing?
100% Toby it will go big wing
its only so all being well when the motor that's in at the mo comes out I can leve it all intact and not start stripping parts off it
Old Jul 19, 2017 | 05:53 AM
  #2842
I just picked up a spare sump myself for a dummy engine set up, amazing how prices for all these bits are going up and up
Did you get a price for your skyline box rebuild yet mate?
Old Jul 21, 2017 | 10:39 AM
  #2843
Hi mate as of yet iv no been intuch again about its as work has been mad and I'm now away for a long weekend with my partner in Cornwall
Old Jul 21, 2017 | 12:51 PM
  #2844
Nice
Enjoy you break mate
The prices of these boxes secondhand has got silly now the us import ban on them no longer applies! Between Ł700 & Ł1000 for one now and a full rebuilt quote I heard someone on the skyline owners forum mention was Ł1800 so it's just not worth it hence why I am going to go the sequential route with PGS in Finland later this year
Old Aug 15, 2017 | 05:20 PM
  #2845
Not much of a update but as my gearbox is out iv had some fittings welded on so I can run a oil cooler.
Old Aug 15, 2017 | 05:24 PM
  #2846
I see a temp sender, will the cooler be linked to run only at certain temp?
Old Aug 15, 2017 | 05:59 PM
  #2847
yes mate it will iv used this setup on my supra rear diff setup for about the last year or so and it works very well for me
Old Aug 15, 2017 | 06:33 PM
  #2848
I thought it would be a similar setup. Will you still run shockproof oil in it?
Old Aug 15, 2017 | 06:48 PM
  #2849
Does it need a gearbox cooler?
Have you measured the oil temps?
Old Aug 15, 2017 | 06:57 PM
  #2850
Surely if it is thermostatically controlled it doesn't matter if he needs it or not, it would kick in if needed and if not it is just a little redundant weight?
Old Aug 15, 2017 | 07:06 PM
  #2851
my point being fitting equipment without even checking the data as to whether its even needed.
Old Aug 15, 2017 | 08:56 PM
  #2852
well all I can say to that is last year we did Bedford autodrome the GT Track and I did 110 miles on track and it was the hottest day of the year and by the end of the day I was struggling to get the car out of gears when on track . And trust me I was giving it all I could . Well a week went past when we had the car home so I did a road test all was good . And sins then Iv done Malory park 2 times . oulton park all day no problems and iv never changed the oil in the gearbox so in my eyes I'm happy to put it on the car .
As said befor iv got this set up on my diff and from time to time I do here the pump kick in . And if Martin hadland had one on his skyline box then it was there for a reason
Old Aug 15, 2017 | 10:06 PM
  #2853
So guesswork really.
You get more heat in the transfer, so 2 x pumps and coolers?
Even the works teams removed pumps/coolers for the likes of cooler countries, only safari/Australia etc had transmission cooling.
If I needed my Skyline box cooling on the rally car it would have it. Currently never needed It, and I have measured temps on rallies.
Old Aug 16, 2017 | 08:24 AM
  #2854
What would be the negative effect of running a cooler. I know the oil won't reach viscosity, but will it affect the box operation that much? Surely if it runs on a stat it will be fine?
Old Aug 16, 2017 | 08:41 AM
  #2855
Too cool is as bad as too hot.Sluggish synchros, increased friction, slow shift, higher bearing loads. There are optimums for all components, that is why measuring is best before adding weight/spending hard earner on something you probably might not need.
Add a couple of temp strips to the box case and see what you record, no need to drill/tap/wire or plumb a sensor in for the first instance.
Old Aug 16, 2017 | 11:48 AM
  #2856
phillgti's Avatar
phillgti
Looking good Ian!!... My Saph is nearly there now so you may see it about in a few weeks
Old Aug 16, 2017 | 02:08 PM
  #2857
ossie cossie's Avatar
ossie cossie
as im in Australia and will be running one of these boxes i will get some aluminium dash fittings welded on my adapted bellhousing before i fit it just incase i have to run a cooler, then i wont have to remove the box to fit it up. If i dont need it i will just put caps on the dash adapters.
Old Aug 16, 2017 | 05:29 PM
  #2858
It won't run any cooler than a normal box if the thermostat is set as the system will be closed and pump off.
I can understand a works team removing it for cold countries as every kilo helps win a race but equally it goes to prove that the quick boys DID run coolers in hotter climates.
Old Aug 16, 2017 | 06:27 PM
  #2859
Good old blighty is hardly a hot climate, and I don't know the OP but I doubt hes a pro driver 😂
Old Aug 16, 2017 | 08:16 PM
  #2860
No but we did see 40 degrees this year and 100 miles on Bedford is pretty hard on a car, in fact an a beginner probably works a car harder than Senna did. If he doesn't generate the heat then thermostat stays closed, all he is doing is dragging some air and a few kilos?
I am not trying to be clever, my point is, if he wants it then do it, no harm.
Old Aug 16, 2017 | 08:52 PM
  #2861
You are not even close to a competitive event doing a track day, trust me I've done both.
I think you are dreaming if you think a beginner can push anywhere near a racer. Not ever 5/10ths
Old Aug 16, 2017 | 08:57 PM
  #2862
[QUOTE=markk;6745092]You are not even close to a competitive event doing a track day, trust me I've done both.
I think you are dreaming if you think a beginner can push anywhere near a racer. Not ever 5/10ths[/QUOTE
Let's not argue for the sake of it, My point is that a closed thermostat makes no difference to the gearbox than one without a cooler other than some weight.
A beginner will change gear more times, over Rev a car more often ask more of an engine than an expert driver and over drive a car, that is what I am saying.
I have done both too and I have seen many a poor driver with a race licence.
Old Aug 16, 2017 | 09:21 PM
  #2863
[QUOTE=Caddyshack;6745094]
Agreed.
I just hate seeing people spending hard earned on things that are not needed. Just a personal bug bear.😉
Old Aug 16, 2017 | 09:33 PM
  #2864
I know you do but sometimes spending the money and trying stuff is 90% of the hobby. Half the stuff we do is a waste, God knows my car would probably be better to drive on the road with half the cost and the over the top crap removed, it is the journey that it fun.
Old Aug 16, 2017 | 10:57 PM
  #2865
Thanks to everyone for there input on wot iv decided to do to my gearbox . As Toby has said these cars are awer hobbies and that's why we have them .
I love messing with the car I made the car wot it is today all my self . I modded the shell to take a 4x4 cosworth my self . I worked it all out my self I did all the welding my self I then decided to put a skyline gearbox in . I modded all the gearbox myself I made the jig to line up the bell housing myself i made all the central push clutch myself i even made myself the front and rear pops for the car and had them balanced properly Iv since had a sliding prop made for it for peace mind
And if I raced It might be a different matter and only parts that was needed would be on the car . But I don't so if I won't to paint it pink I will .
And as to saying i can not drive well have you ever seen me drive No . have you ever been in my car No . So why can you judge me with out noing the facts .
RENT OVER
Old Aug 17, 2017 | 02:54 PM
  #2866
ossie cossie
what size dash fittings are they?
Old Aug 17, 2017 | 03:37 PM
  #2867
hi mate iv only used AN- 6
Old Aug 18, 2017 | 12:10 AM
  #2868
RENT OVER
I know this is your hobby and a good job you have made of it too, but its doing something that is not needed because you don't know if you do is a little like making an adapted to have 4 wheels at the rear, you don't need it.
If you had zero grip, and had proven it then 4 wheels at the rear might improve what you had.
I wasn't commenting on your driving, I was commenting on the comparison between you and a pro driver Caddyshack mentioned. You nor I are Prodrivers, as good as you may think you are, you are not a prodriver, just like I am not.
Old Aug 25, 2017 | 09:08 PM
  #2869
Small update my new front diff tuned up Wednesday witch is now on the car .
I'm over the moon with the service I received from GEARS brand new Crown wheel and pin . And the planetary gears are all so brand new . So a BIG thanks to Andy for sorting this for me and all being well I should have a price for one of my skyline gearboxes
to be repaired this week coming
Old Aug 25, 2017 | 09:17 PM
  #2870
Looks good mate, all coming together
Old Aug 26, 2017 | 01:34 PM
  #2871
ossie cossie
is that brand new 3.9 ratio gears in a standard diff housing ?
Old Aug 26, 2017 | 09:48 PM
  #2872
yes mate
Old Aug 27, 2017 | 02:39 PM
  #2873
ossie cossie
So am i right in assuming you can fit the 3.9 ratio gears in a standard cosworth front diff? or have you just put new gears in a 3.9 ratio diff? I ask as i have 2 spare diffs one std cosworth ratio and one 3.8ratio from a 4x4 sierra but not cosworth. If the gears are available i may buy a spare set just incase.
Old Aug 27, 2017 | 03:39 PM
  #2874
hi mate the diff casings are the same from wot I no and I run a 3.9 front diff from a twin cam . As it's the only front gear set that matches the 3.9 supra diff in the rear the diff has been done by GEARS on an exchange bace as my diff smashed it self to bits
Old Aug 28, 2017 | 02:22 PM
  #2875
ossie cossie
Thanks, do you have there contact info, as like you i got a diff from a twin cam sierra to match the 3.9 supra im putting in mine as well.
Old Sep 1, 2017 | 08:55 AM
  #2876
These are just photos of his page
Old Sep 2, 2017 | 12:00 PM
  #2877
ossie cossie
thank you
Old Nov 5, 2017 | 04:15 PM
  #2878
Well as some of you might no my focos is in bits again as iv cracked yet a nuther 205 block
Any way iv decided not to build my 200 block just yet as I have a spare block I can use for the time being . So all being well I should be sticking the motor back in before Xmas as this spare block I'm going to use is on the same bore size . So today Iv given it a lick of paint . So when I get home Friday from working in Bracknell I can start putting some of it together
Old Nov 5, 2017 | 04:37 PM
  #2879
What’s a 202 block out of
Old Nov 5, 2017 | 04:41 PM
  #2880
A Ford transit van 😀
