(COLEYST200) focus to focos / skyline gear box
#2761
A small update as some time this year or next I'm planning on building a 500 BHP motor . Iv got a crank that iv had for about 3 years now that I'm going to use . I think iv secured a 200 block witch needs some work doing to it but as I'm in no rush I will do the work as and when I have some spare cash . But in the mean time iv all ways been on the look out for a spare head so I don't have to rob parts from the focos motor . Well I think I did ok this weekend as I won two YB heads the one witch I really wanted I got for £445 ye it's not got any valves but I would won't new valves any way . I'm happy with the size
and that it needs some small bits of work doing to it but that's fine . But wot I'm over the moon with is it's had a nice porting job done on the inlet side so that's saved me loads of ££
Caddyshack (17-02-2017)
#2765
On a small update I'm constantly on the hunt for parts to get together for this new motor and along the way if I can save a penny or two I will . Iv got hold of a set of BD14 inlet and ex cams and a set of pullys off a very good member off here .
And as iv got a trackdays next Satday iv bort
some new brake pads EBC BLUE STUFF track and race just hoping my new brake discs turn up now from Martin at REYLAND.
smiley (05-03-2017)
#2768
Never liked the green stuff pads, they leave a lot of fall out on the wheels that seems harder to remove than any other pad. I also found they created more noise than other pads.
#2773
Surely there are better quality pads than green stuff for rally use?
I used a porterfield high carbon on my track car and they were awesome, not cheap and wore the discs quite quickly but they were amazing. Squealed like a piggy until really hot and you had to bake them to bed them in.
#2774
I was meaning for Ian's car.
#2775
Well iv had today off work as tomorrow I'm doing a track day at oulton park and all iv done all day is run around like a mad man lol
but at the end of it the car is now all sorted and a Very Big thanks to Martin Hadland for sorting my new brake discs out in over the moon with them
#2776
I saw he now had floating set up...will be good to see how you get on, have you added more brake cooling now?
#2778
your right mate I did cook them I will take some photos tomorrow when I remove them I had fort the car was braking a bit funny on the rear and was probably why I got a black flag on my last outing as I run wide on a corner lol MSVT told me off for it lol
apart from that the car run spot on all day and we will be going back to oulton park again as it's a stunning track and run very professional.
#2779
The car looks great any more pictures of the track day? What rear discs are you running?
#2782
Oooo that made a mess
#2783
it's chewed for good...
... not something you see often.
#2784
Don't think t cut will polish that out.
#2786
What a great looking car!
#2791
Looks brilliant mate.
#2792
When you run the yellows in the rear for the first time on circuit be cautious.
Ive got a similar brake setup, when i ran DS2500 on the rear it tended to lock up, spun me round at Oulton several times. So i changed to a std road pad and added cooling which improved balance no end.
#2793
#2796
Just a small update as when I did my last trackday at oulton park I sore oil temps upto 115 so to try and help things out a bit iv binned the oil 13 row oil cooler and put a new 25 row cooler back in its place sorry no photos of it at the mo .
Iv all so sent in my 200 block I got off mr Dingla as it needs number 3 bore lining as something with the last owner had it some thing went rong . After it comes out of there its getting sent off to have the long studs done . But in the mean time iv just got some photos of my last trackday .
#2798
One small update today iv picked up my block from my local engine builders ware iv had a liner fitted and I'm over the moon with there work
In the second photo you can just see ware the new liner sits down at the bottom of the bore . And the 3rd photo shows a standard bore. And as the block needed decking that was done at the same time and the good news it only tuck .005 Thou to clean up . So tomorrow I'm off work so it's a road trip down to Xpower Engines as they are the only company that come back to me and there prices are spot on . So more updates to come soon
#2799
Good to see that you are still moving forward. I am about to pull my gearbox and get the selector fork replaced, had some good drives out in mine and now have a list of items to refine.
