Best oil for a trackday ( cosworth)
Old Apr 2, 2017 | 07:34 AM
Default Best oil for a trackday ( cosworth)
hi lads iv done quite a lot of trackdays now and as I'm starting to push the motor more and more on track it's becoming noticeable that the oil I'm using is not up to the job . At oulton park when I come in I had a oil temp of 110 to 115 and the oil pressure on tick over was a shocking 20 psi but leve it to cool down for 3/4 hour and tick over is back to 50 / 60 psi .
Iv all so just removed the 13 row oil cooler and fitted a new 25 row to see if this can help out . But I really think it's time to invest in some proper race not just the run of the mill mobil 1 . I can not tell you the grade as if not got the oil can to hand . You forts on wot would be a good track / race oil for a turbo car .
Thanks for your time lads
Old Apr 2, 2017 | 10:58 AM
Fuchs titan pro race 10w60
Old Apr 2, 2017 | 07:27 PM
slammedorion's Avatar
slammedorion
I'd ring Opieoils tbh, tell them your mods, driving conditions and the temps your seeing and they'll advise accordingly
Old Apr 2, 2017 | 07:50 PM
I have used the above but just changed to 5w50 to help with cold start chatter lol.
Old Apr 2, 2017 | 07:53 PM
A little worrying you dont know the grade you've been using
Maybe it was the wrong grade?
Mobil 1 10w60 should be fine.
If you have been using a watery 40 or below grade that could be a problem, have you got high pressure oil pump?
A good grade 10w50 or 15w50.
I'm now using Fuch Pro Race R 15w50
Old Apr 2, 2017 | 10:56 PM
stevieturbo's Avatar
stevieturbo
C**t
I'm more shocked that idle pressure is 50-60psi !!
Old Apr 3, 2017 | 03:54 PM
True , i assumed this to be running pressure.
Old Apr 3, 2017 | 04:27 PM
I'm assuming it would need to be pretty cold for that pressure Stevie
Old Apr 3, 2017 | 05:19 PM
on cold oil it's about 60 / 65 psi Tick over
when worm its approx 40 psi Tick over
fast road use it drops to 30 / 35 psi tick over
driving worm oil 40 / 50 psi
on track very hot 40 / 50 psi
tick over straight after track time 20 / 25 psi
Leve it to stand for 30 min start it up and it's back in the hi 40,s lo 50,s on tick over
Old Apr 3, 2017 | 06:36 PM
Mine was 43 psi after a hard blast on Sunday at running speed and at tickover I think it was in mid 30's.
Old Apr 3, 2017 | 07:44 PM
lacey's Avatar
lacey
If your cooler is to big that will cause you a issue
With filling it and using the cooler full volume
Old Apr 4, 2017 | 12:35 PM
I use a laminova heat exchanger rather than a traditional cooler and have never had any issues, 25-30 minute sessions flat out
they can also be cleaned out if needed if you had any oil contamination or engine failure whereas a normal mocal air type oil cooler will need to be binned
Old Apr 4, 2017 | 06:08 PM
What doesnt seem to add up is that when warm, you have 40psi tickover and it goes up to 40-50psi driving.
Minimum cosworth oil pressure should be 24psi. I have seen just about below this (like you) when coming off track after a 20min session. But it soon recovers to between 25-30psi. Not an issue IMO.
Looks like you have a std pressure oil pump.
A high pressure one should give 20psi more (driving pressure), warm idle pressure stays the same.
Old Apr 4, 2017 | 11:00 PM
This is what i ran my old moonstone 3dr on track with no issues
