Turbo oil feed pipe NIGHTMARE (had to abandon car 17 miles away) !!
you ignored the advice and its failed, as you were told it would, if you're going to continually post shit on the forum at least listen to the advice people are giving you
Fastlife, get the car recovered to a garage that can fix your turbo oil feed pipe properly, get the oil changed before you run it as more than likely contains bits of your engine, it's more than likely damaged your engine but you'll find that out soon enough.
If it took you 10 days to do up a bolt you shouldn't be working on your own car, professionals have the gear and experience to sort things like that in 5 mins.
Maybe were being a bit harsh,the guys only looking for help.
Fast life,did you try tightening the leaking jubilee clips?
Did they turn at all and if so by how much?
After you tightened them did they leak or not and if not is it possible there was no oil pumping through as it had poured out onto the road?
What size of head is on the jubilee clips,7mm hex or slotted for a flat screwdriver?
How could you tell which of the jubilees was leaking and what order did you tighten them in?
How much coolant was in the header tank and what temperature was it at?also how long ago did you top it up?
Last thing,did your flip flops have oil resistant soles?
on the label reads 10 w 40 semi synthetic motor oil , does that sound like cookikng oil to you, do you cook food in motor oil ?? you daft cunt
I went up there today (got bus) spent hours but got ti home no problem ! had to buy more clips at B&Q as ones I had kept spinning and not getting tighter.
drove it home, drives absolutely fine, no strange noises, no burning smell, nothing wrong at all ! In under 2 years the oil light has come on about 5 timers mainly different problems regarding this pipe, but every single time I have noticed right away and switched the engine off immediately like a second or 2 later and has been perfectly fine !! I'm lucky that I have noticed right away but not so that the light came on. same with water pipes, had about 10 times in almost 2 years leak/burst and caught all before disaster.
why change oil ? was low and I kept topping up with new oil while trying to fix it so all old oil will be out the system.
why should I not work on my own car ? Over the past 6 months my car has required basically a full suspension rebuild and brakes, glow plugs, radiator, e.t.c. and I have done all those repairs myself, no problems with any of the repairs I've carried out, no unusual noises, passed it's MOT e.t.c.
I have no training or qualifications in this industry of car mechanics, but I have self taught and learnt a lot and a lot of what is involved is common sense, I will certainly not quit doing repairs on my car, I'd rather not have to repair anything on it but if needs be I am more than willing to fix the car myself and capable of doing so.
btw, here is a short video of the bolt in question and why it took so long to do it.
yes, I went up there today on the bus, spent hours but finally did it, the clips were the type that require flat screwdriver, while tightening they were turning and before many of them even got tight they stripped the thread and just kept spinning, ended up going into B & Q and buying more, they cost a lot but were much better, drove car home 10 - 15 miles or so, drove absolutely fine, no unusual noises, no unusual smells of burning or anything, I will get the pipe replaced.
1 thing is for sure after all the oil leaks its had in the last 2 yrs as you say the underside will never rot! Next time just take the clocks out and remove the bulb for the oil pressure light and keep driving job done no more scary light and more oil to top the underseal up
[QUOTE=FastLife91;6725185]on the label reads 10 w 40 semi synthetic motor oil , does that sound like cookikng oil to you, do you cook food in motor oil ?? you daft cunt
Cookikng oil lol and iam the daft cunt, at least I can use a spanner without asking for help on a forum.
[QUOTE=zetaboostboy522bhp;6725207]
get lost
https://www.youtube.com/watch?v=6bA6VsKCH4c
The oil light comes on usually when the damage has been done.
By all means keep fixing/bodging the repairs yourself but it sounds like you'd have saved yourself money having a professional look at it and repair it correctly.
Because of the lack of oil, it's the qualities of the oil that will have degraded as it will have got hot also like I said most likely bits of filings in the sump.
From: An Essex lad now in Christchurch, New Zealand.
Man... There are not many times in my life that im speachless but.....
I believe we should give Fucklife91 an instant Gold membership.. Save him 10 quid.. by god, it sounds like he needs it for spare parts..
1.slow, dangerous brian, dropped on head when born, exxon valdez, fastlife91 leak again, fisher price tools out, focus flid, fucking tragic, get the bus dumbass, get the crayons out, haha-nelson-simpsons, hiking boots/flip flops, horse teeth, isis car bomb, jim'll fix it, kaboom!, mr ed can gallop, my mum says i'm special, on the fucking trumptrain, on the short bus, peter griffin is smarter, ricky retard, sam dingle's brighter, shares in northsea oil, taxi for retard, tony blairs focus, walkers bus, walking bottle opener, what's that smell, window licker
