V8 Sierra 2WD
Old Sep 10, 2016 | 05:47 PM
  #521
Cossie 2wd hubs?
If so what about the brembo caliper 350 kit from compbrake? I used it on my last saff and they are now going on the cortina. Ping me a text and i will find a pic and sendvia whatsapp.
I used 8 x18 focus rs alloys so that could be a starting point....
Old Sep 10, 2016 | 05:51 PM
  #522
Wheels are et42.
Old Sep 10, 2016 | 05:56 PM
  #523
Just sent text.
I've ordered a set of Revolution millennium in 17 inch and they are 3 door Cossy hubs.
8 x 17 ET40 rear and 7.5 x 17 ET37 front
Edit as I've just spotted the pic - looks like they might squeeze under 17's
Whether I could get an outline drawing from Compbrake is another question !
I think I've convinced the guy at Revolution to send me a drawing of just the inside profile of the wheel.
Don't want to guess on if the parts will all fit.
Old Sep 10, 2016 | 06:32 PM
  #524
New old stock wiper mechanism - sticker on it said November 1996 so not so new and a bit scruffy ...
A quick going over with a scotch pad and then some 2 pack satin black.
Cleaned up the old mounting rubbers as they are NLA, managed to track down a set of the metal bobbins.
Cleaned up original motor cover and fitted new wiper motor.
I've been tracking down bits like this for years, now all the hoarding in paying off
Old Sep 11, 2016 | 01:34 PM
  #525
Originally Posted by costina
Wheels are et42.
Looks like that cars had a little bump
Old Sep 11, 2016 | 01:49 PM
  #526
Big brakes do not stop you going sideways........
Old Sep 11, 2016 | 04:36 PM
  #527
SMILER258's Avatar
SMILER258
This build still makes my jaw drop. The attention to detail and quality of your work is insane!
Old Sep 13, 2016 | 06:58 PM
  #528
So much for a 5 door being cheaper than the EsCos to do up
Would have been much cheaper and quicker to stick to the original plan, but I like sleepers and this should surprise a few people !
Old Sep 13, 2016 | 07:10 PM
  #529
merkur's Avatar
merkur
Will you add any metal to the top of the rear shock mounts if you're going to be running a rear coilover?
Old Sep 13, 2016 | 07:29 PM
  #530
I've been told a rear strut brace will be more than enough if the car is not rusty
Old Sep 13, 2016 | 08:03 PM
  #531
I did'nt run a brace on my saff but as yours is a hatchback you will need it and notice a difference.
Would it be a idea to tie the brace in with rear diff mount ? Could be a nice mod.🤔
Old Sep 13, 2016 | 08:15 PM
  #532
I've considered it, but it would mean chopping the floor about as the diff mount bolts to a floating plate within a box section.
Probably try the lazy option first and just a regular brace.
Old Sep 13, 2016 | 08:22 PM
  #533
It would only require 4 oversized holes in floor.
Old Sep 23, 2016 | 04:04 PM
  #534
coco16i's Avatar
coco16i
Just had a read through this thread from start to finish and blown away by your attention to detail with this build, properly stunning mate and your fabrication skills are fucking amazing !!
Old Sep 23, 2016 | 10:34 PM
  #535
xr2john's Avatar
xr2john
Passionford Addict
Awesome build. I've read this a couple of times and would love to have the skills to build something like this. Cars going to be a minter when it's finished and FairPlay to you. Can't wait to see it finished
Old Sep 30, 2016 | 06:54 PM
  #536
Got as far as I can with diff cover until I can figure out how to make a PC talk to a Mazak FJV20 machining centre.
It is proving far harder than I imagined !
Old Sep 30, 2016 | 09:02 PM
  #537
I was on the mill today for the first time in years nothing as exotic a that tho.
Looks very nice.
Old Oct 15, 2016 | 04:18 PM
  #538
Got a bit more done, getting a PC to talk to the CNC mill has proved to be a pain in the ass !
Coolant turned off for the quick vid
http://vidmg.photobucket.com/albums/...ps48scbkbe.mp4
The other side is going to be far more difficult to get my head around.
Cleaned all the dodgy paint from recon rack
Epoxied it and then gave it a squirt of satin black
Newish steering coupling in need of some TLC
All done
Did a bit more dynamat today, but rain stopped play !
Old Oct 15, 2016 | 07:37 PM
  #539
xr2john's Avatar
xr2john
Passionford Addict
Coming on
Old Nov 6, 2016 | 06:44 PM
  #540
Diff cover was going OK
Then the CNC had a spaz attack and smashed the cutter to bits
Took a big chunk out of the cover also, don't know if it's a post processor problem or a fault with the machine...
On the positive side a nice parcel from Martin Hadland showed up with some bling brakes.
I sent him a wheel to check clearances and he sorted out some 335mm fully floating discs discs and CP9200 calipers.
Got some matching discs for the rear also
Revolution wheels are any colour you like as long as it's white, I would have preferred silver though !
Old Nov 6, 2016 | 09:21 PM
  #541
Very nice Mark.
Can u not tig the coverand re machine?
Thats a big lump of alloy to scrap....
Old Nov 7, 2016 | 01:06 AM
  #542
just read the whole thread excellent work!
Old Nov 7, 2016 | 01:38 PM
  #543
Loving the brakes matey.
Old Nov 7, 2016 | 06:05 PM
  #544
Very nice Mark.
I'm going to remove all the fins and get the damage welded, I've given up with the Mazak as the damn thing has a mind of its own.
The plan is to finish off on our little Bridgeport Interact CNC.
Fingers crossed
Old Nov 9, 2016 | 03:11 PM
  #545
merkur's Avatar
merkur
Stunning as always!
Old Nov 12, 2016 | 03:35 PM
  #546
Diff cover is beginning to look like a real one now
Fins machined off and a dab of weld on the remaining damage cleaned up OK
Took bloody ages to do the Ford Racing engraving !
Still plenty to do, but getting there.
Old Nov 12, 2016 | 03:58 PM
  #547
merkur's Avatar
merkur
Holy sh*t balls batman!
That's beautiful.
Nice job!
Old Nov 12, 2016 | 04:56 PM
  #548
Wow that's stunning.
Old Nov 12, 2016 | 08:07 PM
  #549
xr2john's Avatar
xr2john
Passionford Addict
Now that's an awesome bit of custom work. Should be well pleased with that I would say. Wonder how many people are going to see it and ask you to make more
Old Nov 12, 2016 | 09:00 PM
  #550
Fuck making any more
Old Nov 13, 2016 | 05:43 PM
  #551
Mark.
That diff cover is fantastic.
Old Nov 19, 2016 | 05:45 PM
  #552
Did a few more hours at work today on the diff cover and it's nearly done
Old Nov 19, 2016 | 07:25 PM
  #553
xr2john's Avatar
xr2john
Passionford Addict
Stunning as always
Going to be an awesome sleeper hatch if ever there was 1
Old Nov 19, 2016 | 07:29 PM
  #554
turbo m's Avatar
turbo m
WOW!!! just WOW!!!!!
Old Nov 22, 2016 | 04:01 PM
  #555
CozzyKing's Avatar
CozzyKing
That's stunning Mark.
Old Nov 25, 2016 | 12:26 PM
  #556
GrahamGarner's Avatar
GrahamGarner
If you get manifold issues you can make your own, I have.
http://www.ebay.co.uk/itm/1320138867...84.m1555.l2649
Old Nov 25, 2016 | 03:59 PM
  #557
Made them ages ago mate
Your welding is much nicer than mine though ! - I prefer the collectors on mine to the ones in the advert ...
Old Nov 25, 2016 | 04:11 PM
  #558
GrahamGarner
I have them welding done profesionnaly, thats why I offer them a lot cheeper unwelded as this is around £10 per joint weld (£100 each).
The one's on the listing are made for bolt straight on thats why they are merged like they are. Only having manifolds to copy and not cars to work from that is all I can do. eBay screw 10% and Paypal another 3%.
Graham
Old Nov 25, 2016 | 04:29 PM
  #559
Graham
I would say £10 per joint is not bad if they're back purged with Argon, cost me a fortune is gas to do mine
Old Nov 25, 2016 | 06:01 PM
  #560
GrahamGarner
I know, I tried hobie gas, £40 a pop for a small bottle, only lasts a few hours.
