V8 Sierra 2WD
#602
Some real quality workmanship going into this car can't wait to see the finished car 👍👍 the polishing machine you used on the bolts where's that from cleaning bolts by hand on mine is getting tedious
#603
Got it from Amazon £76
The polishing media that comes with it is not much good for bolts, I bought some fine crushed walnut sand from a pet shop and rubbed in a bit of solvol autosol.
Takes a long while to get them shiny though !
EDIT to add that I sold the parts polisher on Ebay after I had finished with it for £88
#604
More bits stripped and cleaned ready for Zinc plating.
I've already done a set of 3 door hubs, but the fact that the unpainted parts will quickly rust is bugging me
Will sell the spare set when these are finished...
#606
It was Bohler M238 - they sell a lot of it to motorsport companies for making shafts.
http://www.bohlersteels.co.uk/english/1179.php
#609
They look great a quick turnaround too. I'd want to leave them like that but I know they'd tarnish
#613
Thanks guys.
Very long day getting the front off the dolly wheels and all the suspension and steering on.
To make life much, much easier I spread the cross member a bit to give me a fighting chance of getting the TCA's in without beating the crap out of them.
Just need to sort the rear end out now!
#615
Lucifer II - 666
Stunning!
H3lsing (10-09-2017)
#619
Not done a lot as I've changed my daily driver and been messing with that instead
Had it remapped by MRC and it goes like the clappers.
I have done some on the Sierra though!
Made a carbon fibre rear strut brace over the winter
Cosworth drive shafts were too long to fit with the Jag diff and I had to get some shorter ones made.
Painted them last weekend
Built them on the kitchen table
Hid from the sun today under the car fitting them and the 4x4 Cosworth ARB
#624
Fantastic build, are those Black Art Coilovers.
#626
Nice, they are supposed to be very good, I have a set going on mine
Mark V8 (30-05-2018)
The following 2 users liked this post by merkwerke:
Mark V8 (26-07-2018),
sierra1off (03-11-2019)
#631
I've been slacking with the updates!
A few years back I bought some door looms on Ebay, but they did not have enough wires for my setup so had to swap the rubber grommets over - took bloody ages.
Got to love new old stock, £140 well spent for the full set
Cleaned up all the original glass and re-fitted it.
Now I'm on the wiring
#633
Loads of room. For now it just has shorty headers on it that take up about the same room as cast iron manifolds. And it's not as "tight/snug" as people think. Between the frame rails it's wider than the Mustang! The Mustang does have more depth though.
#634
[QUOTE=Mark V8;6776980]
/QUOTE]
Hi Mark V 8
Where did you get this from. I'm looking for a full set for my sapphire - just the outer trims is all I'm needing. I'm battling to source. Is it worth requesting from Germany. Who can help me with this?
Here in South Africa, these items are obsolete from the agents. I've been going to scrappers and they all have similar issues corrosion and bubbling. Any ideas?
/QUOTE]
Hi Mark V 8
#637
Got the carbon tube and adhesive from Easy composites
CFT-WF-40-37-1 40mm(37mm) Woven Finish Carbon Fibre Tube - 1m Length
VM100B-25 VM100 Black 10min Methacrylate Adhesive 25ml Syringe
sierra1off (18-09-2018)
#638
I've been putting this off for a while, but it needed doing so all the wiring can go back - scabby bulkhead panel attacked with paint stripper and 'Phosclean A' acid for the rust.
Acid was so strong it melted the scotch pad in less than a minute, stings your hands like a bastard as well
It's a bit thin in places so I soldered up the thin area and filed it smooth before laying on a load of epoxy mastic chassis paint, sanded it all over then more epoxy, sanded again with 600 wet and dry followed by some 2 pack satin black.
No pics of the finished article yet
