FOCUS RS 4x4 COSWORTH 24 - 02 - 2013
Old 19-09-2010 | 03:47 PM
  #761
bigboot5's Avatar
bigboot5
can i ask where th ruber mounts are from exactly what im look at for mine
top work regards tommi
Old 19-09-2010 | 08:56 PM
  #762
mp0109's Avatar
mp0109
hi m8, how you getting on with the conversion?
Old 19-09-2010 | 10:08 PM
  #763
focus 4x4's Avatar
focus 4x4
Very average mate.
Old 19-09-2010 | 10:15 PM
  #764
mp0109's Avatar
mp0109
im looking to do a similar conversion or buy a conversion all done, thought id get the run down from ya to see what problems you have come across
Old 19-09-2010 | 10:18 PM
  #765
focus 4x4's Avatar
focus 4x4
Dingla off here has a converted shell for sale , id buy that if i was you. and build from there!
Old 19-09-2010 | 10:20 PM
  #766
dingla rs's Avatar
dingla rs
that i do and its cheap
Old 19-09-2010 | 11:13 PM
  #767
mp0109's Avatar
mp0109
how much do you want for the shell also do you have pics?
Old 11-10-2010 | 04:30 PM
  #768
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
Had half an hour on the focus tonight so i continued with the rear braided brake lines.....
And while i was down there , you might appreciate these aswell ;o)
Brake lines finished yet ???
Old 11-10-2010 | 05:18 PM
  #769
focus 4x4's Avatar
focus 4x4
Yes Carl , all done mate , even got them bled and also have a decent pedal. fuel lines and wiring loom next ...... cant wait! ;o(
Old 11-10-2010 | 05:27 PM
  #770
dingla rs's Avatar
dingla rs
is the porky urs then mate in ur avator,looking forward some one doin a loom so i can see how hard they are to do
Old 11-10-2010 | 05:31 PM
  #771
focus 4x4's Avatar
focus 4x4
Managed to get some free brake fluid from a good friend whos sponsored ! Cheers Craig.
Brakes all finished , PHEW!
Old 11-10-2010 | 05:33 PM
  #772
focus 4x4's Avatar
focus 4x4
Yes mate it is/was ! Major boo boo with the porsche , i sold it . ;o(
Old 11-10-2010 | 05:35 PM
  #773
focus 4x4's Avatar
focus 4x4
Im gonna try and do away with the massive fuse box in the focus engine bay.... so wish me luck. doing he cosworth brake loom atm ;o(
Old 11-10-2010 | 08:23 PM
  #774
focusv8's Avatar
focusv8
It's not too hard to fit it in the glove box;
Old 11-10-2010 | 08:25 PM
  #775
whizzisat114's Avatar
whizzisat114
Look's good in there Simon will soon disapear ay
Old 11-10-2010 | 08:48 PM
  #776
focus 4x4's Avatar
focus 4x4
Now i do like that idea!!!! i love it when a plan comes together !!!
Old 11-10-2010 | 08:57 PM
  #777
focusv8's Avatar
focusv8
Check the top left corner of the black fuse box and you'll see it's hinged so it folds out to get access to the other fuse box.
There are more wires going from inside to outside through the wheel arch so you end up with less wires passing through the arch.
Note brown and grey connectors on the floor, they are normally through the arch.
Old 11-10-2010 | 09:12 PM
  #778
whizzisat114
So you have not used the connector's through the arch?
Old 11-10-2010 | 09:38 PM
  #779
focus 4x4's Avatar
focus 4x4
What a perfect solution!!! i have a complete cosworth floor and bulkhead fitted in my focus so ill need to pass the focus loom through the cosworth bulk head , should be pretty straight forward...... might need to extent some of the loom so that the connectors for the lights etc etc actually do reach!?
Old 13-10-2010 | 02:19 PM
  #780
focus 4x4's Avatar
focus 4x4
Made a start on the wiring today , so first things first i thought id tidy up the ABS brake loom . I cut out all the unwanted bits ( 4x ABS sensors and the ABS light) then i pulled the power supply wires back through the bulkhead grommet as the power feed will now come from under the dash.
Next step is to modify the standard focus fuse box loom so it also passes through the ABS brake loom grommet in the bulkhead so i can relocate the fusebox under the dash..........
Old 13-10-2010 | 04:31 PM
  #781
COLEYST200's Avatar
COLEYST200
keep us all up to speed on this mate as were have all got to do this job
Old 13-10-2010 | 04:45 PM
  #782
focus 4x4's Avatar
focus 4x4
Will do , im just doing what i "think" is right lol plus checking with an auto electrician with every step and "cut" lol
Old 14-10-2010 | 07:54 PM
  #783
focus 4x4's Avatar
focus 4x4
Got a chance tonight to get back under the car and fit a pair of much awaited brackets to stop the rear bumper flapping about at high speeds.......
Soild as a rock! ;o)
Old 14-10-2010 | 08:16 PM
  #784
whizzisat114
Looking Good Simon very tidy under there
Old 14-10-2010 | 10:39 PM
  #785
Gaz 88's Avatar
Gaz 88
Loving how everything is made to order and the best quality on this!! Did pro make the brackets for you?
Old 14-10-2010 | 10:51 PM
  #786
COLEYST200's Avatar
COLEYST200
NICE
Old 17-10-2010 | 02:39 PM
  #787
focus 4x4's Avatar
focus 4x4
Grabbed another wiper mechanism from the local breaker (Ł15) ;o)
So the mods were done......
BEFORE
Modded
AFTER
Old 17-10-2010 | 04:23 PM
  #788
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Fantastic work
This is probably the only car I would ever consider buying knowing everything was 'just right'
Old 17-10-2010 | 04:37 PM
  #789
COLEYST200's Avatar
COLEYST200
Dont forget to check the strock when you put ut on the car as when i did my wiper it went off the window pillar so please please remember this as it will trash your paint job in one hit . And all so remember you have to re time the arm on the motor
Old 17-10-2010 | 04:44 PM
  #790
focus 4x4's Avatar
focus 4x4
Thanks Coley
Oh dont worry ill be trying it very very manually and carefully a number of times before i hook it up to the electric!
Old 17-10-2010 | 05:00 PM
  #791
COLEYST200's Avatar
COLEYST200
good lad
Old 17-10-2010 | 06:44 PM
  #792
whizzisat114
Which were the pin numbers that you have to live up to make the motor work and park again Ian i think that would be of some use to people doing the mod
Old 17-10-2010 | 07:22 PM
  #793
fezzajsy's Avatar
fezzajsy
mate quick question,what size are the fittings and braided brake pipes pliz?
ps cars getting there,well done
Old 17-10-2010 | 07:26 PM
  #794
fezzajsy's Avatar
fezzajsy
mate what size are the fittings and braided brake lines?how long did u use?thanx
ps
Old 17-10-2010 | 08:00 PM
  #795
COLEYST200's Avatar
COLEYST200
I will go and sort this out for you DAVE as it one of the things i never put on my post about doing this
Old 17-10-2010 | 08:01 PM
  #796
focus 4x4's Avatar
focus 4x4
The brake lines are all ptfe lined -3 and the fittings are all size M10x1.0 .
hope that helps ;o)
Old 17-10-2010 | 08:44 PM
  #797
COLEYST200's Avatar
COLEYST200
iv put some info on my post about wot wires to clip on to to make the wiper motor work
Old 18-10-2010 | 06:00 PM
  #798
fezzajsy's Avatar
fezzajsy
cheers mate
Old 22-10-2010 | 08:36 PM
  #799
focus 4x4's Avatar
focus 4x4
Fitted the modded wiper mechanism tonight and suprisingly WITHOUT having to shorten the wiper motor arm . i simply adjusted the amount of "throw" i need on its splines instead of cutting the motor arm. Heres the results.....
And in the rest position.....
Couldnt resist trying the MK2 wheel..... hmmm ????
Old 22-10-2010 | 08:45 PM
  #800
COLEYST200's Avatar
COLEYST200
Im glad your happy with the wiper mod when its in place it looks like ford made it this way . nice bit of dust on it mate
Quick Reply: FOCUS RS 4x4 COSWORTH 24 - 02 - 2013
